how to stop P0300 code with edit
7.3.1 Misfire detection
The Maximum Temperature and Minimum Temperature define the temperature range over which the test is run. You could make these both above the normal operating range, so the test isn’t run.
A better solution is to let the test run, but fine tune it so it doesn’t show misfire counts when the engine is running normally. That way if you crack a plug, or have an injector go bad, you will get an error code. When you put a large cam in these engines, the misfire test will falsely identify a misfire. You can loosen up the test at idle, and get rid of these errors. Set the test value in the idle and low RPM tables to 32000, This will loosen up the test, so it should always pass. The test at mid RPM will still be functional.
FWIW. This works well for most. Good Luck.
