C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Cat codes shutoff help
Old Feb 20, 2004 | 03:09 PM
blktie8's Avatar
blktie8
Default Cat codes shutoff help
When the rear 02 are shut off with Ls1 edit can they be removed
cable harnass taped ?
Do you guys leave the 02 's connected on an off road pipe ?
Old Feb 23, 2004 | 11:53 PM
Mr Cowl Hood's Avatar
Mr Cowl Hood
Default Re: Cat codes shutoff help (blktie8)
The answer is yes. I just can't believe the paying venders don't answer easy questions like this.:eek:
Yes, once all CAT test codes are disabled, including 420 and 430 :yesnod: you can do with those connectors as you please. If you're not able to connect the rear O2's to the exhaust in the usual way, you can leave them connected and tie them up into the bottom of the floor boards. Otherwise tape off and seal those connectors well. Not taking care of that may come back to haunt you.
Good luck! :cheers:
[Modified by Mr Cowl Hood, 10:54 PM 2/23/2004]
[Modified by Mr Cowl Hood, 10:55 PM 2/23/2004]
Old Feb 25, 2004 | 03:30 PM
davidcheese's Avatar
davidcheese
Many of the off road setups I have seen built leave the holes for the o2 sensors. That way you can leave them bolted in without chopping uo the wires in case you ever want to return the car to stock. For my setup, we added an x-pipe where the cats were, but left the section in with the o2 holes.
Old Feb 26, 2004 | 03:36 PM
Mr Cowl Hood
Default Re: Cat codes shutoff help (davidcheese)
You should never chop the wires, just zip tie them up into the bottom of the car, or, like you said, maintain O2's on them in some bungs. Either way will work.
Old Mar 1, 2004 | 02:54 PM
blktie8's Avatar
blktie8
I have the 02 removed and shut off I want to use the bungs for A/F
WIDEBAND
I have no cats
Again thanks
To Cat codes shutoff help
