C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Check Engine Lite
Old Apr 27, 2004 | 07:47 PM
gairno's Avatar
gairno
Default Check Engine Lite
I have a 2000 C5 and I have put the Kooks headers on with the twin flow K&N fitler system. After installing the headers I have a check engine code the comes up P0410 which is air system. I have also put in the 02 sims. With help from Shawn and Al at L.A.P.D. I think we are about to get over this. These guys will go out of there way to help you in any way they can. If everything that I've done does not get rid of the code I will have to have it dynoed at L.A.P.D. Thanks, to Shawn and Al for all there help over the last month. I think I may be over the problem. Al told me to pull fuses 16 and 23 to reset the computer. I did this and it reset the computer back to stock. I left it alone for a few day's and then put the performance tune back in from the Diablosport and know lite has come on. Thanks, Al.
[Modified by gairno, 8:09 AM 4/28/2004]
[Modified by gairno, 8:10 AM 4/28/2004]
[Modified by gairno, 12:33 AM 5/3/2004]
