C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
EFILive6 question
Old Apr 29, 2004 | 10:56 PM
ArKay99's Avatar
ArKay99
Default EFILive6 question
What is FUELSYS-A and FUELSYS-B? What do they monitor. I assume it is fuel system status, but what does that mean? The gauges go red from time to time and report OL-Drive. Haven't found an explaination at EFILive's website, or in the help.
Old Apr 29, 2004 | 11:29 PM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
Default Re: EFILive6 question (ArKay99)
They monitor whether the car is in Open Loop or Closed Loop.
Closed loop is when you are cruising around town and your AFR is being monitored by the 02s so the car can attempt to keep a 14.7AFR. Your LTFTs(Long Term Fuel Trim) should be in the -1 to -3 range here or there abouts. You want them to be negative in closed loop so when you go to WOT then they will change to 0. When you go to WOT, then the car goes into Open loop and no longer communicates with the front 02 sensors and just 0s out the LTFTs.
Old Apr 30, 2004 | 12:12 AM
ArKay99's Avatar
ArKay99
Ok, that makes total sense. OL- Drive means open loop - drive, and CL means closed loop. Thanks!
To EFILive6 question
