C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
HELP with Codes
Old May 13, 2004 | 09:43 AM
mgora1's Avatar
mgora1
Default HELP with Codes
I just installed headers and high flow cats. The installer did LS edit tweaks but I am getting a P0141 and P0161. as well as the check engine light. I have reset the codes but they come back after a few minutes. Is there a concern with driving the car before I can get someone to look at?
Old May 14, 2004 | 10:42 AM
ArmyVette's Avatar
ArmyVette
Default Re: HELP with Codes (mgora1)
P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
Here's the link. Bookmark this. You'll probably use it frequently...hopefully to answer someone else's questions!
http://www.stengel.net/diccodes.htm
Old May 18, 2004 | 11:10 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
May need to have your rear O2 sensor codes deleted in the PCM. You can also try O2 Sensor Simulators.
Sometimes people need one of these 2 options even with cats.
Old Sep 17, 2004 | 07:10 PM
jeff1surfs's Avatar
jeff1surfs
Thanks, I am going to check a car right now, this will help me alot.
To HELP with Codes
