HP tuner help
( heads & cam later in the summer )
I had planned on getting a dyno tune when I'm done but it's going to cost as much as HP tuner would. I was wondering, with the mods that I have, could some of you folks help me out with a tune if I purchase HPT. I'm trying to squeez this all in before my next Time Trials on the 12th ?
Good Luck.
You don't really need a dyno until you have tweaked on the car using your datalog. Here is a very basic and effective way to do so.
Using HP Tuner:
1. SET UP YOUR SCANNER TO DATALOG
File->Connect
Scan->Start Scanning
RPM
O2 BANK 1 SENSOR 1
02 BANK 2 SENSOR 1
STFTB1(Short Term Fuel Trim)
STFTB2
LTFTB1
LTFTB2
Post or send it to me.
2. IDLE/LOW END and to setup for wot
After warming up your car to operating temp, you need to ~ZERO your STFT.
You should already be very close though your airbox will throw it off.
If your idle fuel trims are > 0, decrease your "Injector Flow Rate vs KPA" until they are close to zero. (Note a decrease in the flow rate indicates the engine has smaller injectors and will cause an increase in fuel enrichment)
3. WOT
Make a few WOT passes in 2nd or 3rd and check the o2 voltage at WOT.
Lets just say 0.925v to 0.945v is a good starting point. Less voltage=leaner, higher=richer. For my car, 0.945v is ~ 12.7:1 A/F.
Now, gets a bit more complex:
Note the following about HP Tuner: The injector flow rates in HP Tuner are setup in KPa. This means the value to the far left of the table is 0 vacuum or WOT and the value to the right is IDLE or max vacuum. You can scale your fuel curve by adjusting this.
Knowing that you already have it set for idle, do the following:
1. If the WOT run indicates enrichment is needed, DECREASE the values to the far left of the table (0 vac, wot) otherwise increase them. You should carefully scale this through idle. For example, if a 4% change is required at wot, then scale it roughly 2% in the center of the table, etc.
2. Granted, some will tell you to use the WOT PE RPM table and that is fine.
Just note that the PE table is setup to select a commanded air fuel.
For example, at 6000RPM, the value in a PE table might be 1.22 on a Z06. That represents a commanded fuel of 14.682/1.22 = ~12:1 A/F. If your injector scaling is correct from above, your PE table = Wideband value. This is not absolute as there are obviously are areas the pcm enrichs/enleans fuel, but it will get you VERY close.
4. ADJUST SPARK
Cut the data below using "copy" and paste this to the far left and upper block
of your spark table. This will only work in HP Tuner.
Example: high octane spark table for 91 octane w/aftermarket cam (if no cam increase low load spark; aftermarket cams with ground in advance increase cylinder pressure, ie cause pinging at low load):
http://home.comcast.net/~booth.p/high_octane_spark.txt
the week before my next time trials. I don't want to screw things up.
I guess I'll take things in small bits and hopefully I won't start throwing codes.
I'll post results soon, thanx again
WOT PE table:
1.203 1.203 1.203 1.197 1.192 1.167 1.167 1.222 1.239 1.307 1.344 1.314 1.427 1.438 1.39 1.392 1.405 1.45 1.212
After some adjustments, still too lean:
1.203 1.203 1.203 1.197 1.192 1.167 1.167 1.222 1.255 1.35 1.355 1.357 1.457 1.459 1.479 1.48 1.485 1.45 1.212
I still need to make adjustments to the PE table, but how much?
