C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Uncoiding Diagnostic codes
Old Jun 20, 2004 | 02:46 PM
rpuerzer's Avatar
rpuerzer
Default Uncoiding Diagnostic codes
Hi:
I did a manual Diagnostic code readout and came up with the following codes:
Could you please tell me what the refer to:
60-IPC
BO521 H
U1160 H
U1255 H
I haven't had any problems that i am aware of and the 02 Zo6 is under warrenty.
Any help would be appreciated.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Old Jun 20, 2004 | 08:55 PM
0rion's Avatar
0rion
Default Re: Uncoiding Diagnostic codes (rpuerzer)
U1255 Serial Data Line Malfunction -RFA
U1160 Loss of Communications with LDCM
B0521 TACH Signal Out Of Range
Those are all History codes for you (H) so just erase them and see if they come back.
Old Jun 23, 2004 | 07:19 AM
rpuerzer's Avatar
rpuerzer
Default Re: Uncoiding Diagnostic codes (0rion)
I have tried to reset (remove the Diagnostic Codes to see if the system is now clear. However, I haven't been able to remove them. Is there a way to remove the codes without going to a dealer. [IMG][/IMG]
Old Jun 24, 2004 | 10:52 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
When you access the codes and they start to run through the display push reset and it will advance to the manual diagnois mode. When you find an area that displays a code hold down the reset button until the code clears. Advance through the menu I believe with the fuel button, might be the gauge button.
Old Jun 25, 2004 | 12:49 AM
Dirty Howie's Avatar
Dirty Howie
Sorry, but can you tell me how you to get to the readout.....which button combo is it that you need to push.....Thanks!
Old Jun 25, 2004 | 10:00 AM
rpuerzer's Avatar
rpuerzer
Default Re: Uncoiding Diagnostic codes (Threed)
I really appreciate the information. i was able to clear the codes.
[IMG][/IMG]
Old Jun 25, 2004 | 10:12 AM
rpuerzer's Avatar
rpuerzer
Default Re: Uncoiding Diagnostic codes (Macinamouth)
Hi:
To get the codes do the following. Put the key into the ignition and turn to on--but do not start. The DIC will go through its cycle "General Motors Corvette--ECT----When that finishes hold in the options button--While the options button is held in press the fuel button 4x. This will take you to the Diagnostic display which will go through all of the various computer modes. If there are codes they will appear after the computer mode. this will run through the whole cycle automatically. When the auto cycle is complete, it will go to a manual mode. The options button will take you to each code. If you have an error-- by hitting reset the error will be removed. The options button and the one above it will take you manually through all of the possible errors and you could remove them one by one if you want.
I just went down to the "Z" and know that this will work--- Good luck---
Wonderful Forum with a lot of quality info.
[IMG][/IMG]
Old Jun 25, 2004 | 03:06 PM
rpuerzer's Avatar
rpuerzer
Thanks for the information. It was very helpful [IMG][/IMG]
Old Jun 25, 2004 | 08:51 PM
Dirty Howie
THANK YOU!!
To Uncoiding Diagnostic codes
