C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
ABS Reprogram Question
Old Jul 23, 2004 | 09:33 AM
Roadking's Avatar
Roadking
Default ABS Reprogram Question
I swapped out my stock C5 wheels with Zo6 wheels and tires. Do I need to reprogram for ABS and active handling?
Old Jul 23, 2004 | 11:06 AM
leaftye's Avatar
leaftye
AFAIK you only need to reprogram the tire sensors, but if you swapped the tire sensors over and kept them on the originals corners, this is a non-issue as well.
How do you like your new setup? When I did it, I had to relearn how to break the rear end loose again! Soo much more grip! Try throwing on something in the Nitto 555 series and you'll really be hooked!
Eugene
Old Jul 23, 2004 | 12:45 PM
Roadking's Avatar
Roadking
Changed over the sensors, no big deal. I like the look and the set up is great. Nitto's may be next. The concern I had is a corvette mechanic told me I need to reprogram the computter otherwise the ABS and the active handling will not work properly. He said some one he knew of totaled out his Vette with the Z06 setup.
Old Jul 23, 2004 | 10:24 PM
leaftye's Avatar
leaftye
All I've heard is that if you keep the same overall tire/wheel diameter ratio front-to-rear, all should be well with Active Handling. If you try to run different sizes, or even widths, it could confuse the system. If you're running stock Z06 sizes, or even if you get the 10mm wider Nitto's for them, you should still be okay. If you're worried, this would be a great reason for you to do an autocross. It might be fun, but more importantly, you'd learn if you can handle your car safely.
Eugene
Old Jul 24, 2004 | 09:12 AM
Roadking's Avatar
Roadking
Thanks for the info.
To ABS Reprogram Question
