C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
i maybe wrong
Old Oct 27, 2004 | 08:59 AM
tramminc's Avatar
tramminc
Default i maybe wrong
but i always though a bigger spark on the plug gives more housepower so why do some people use a lower sparking plug while tuning a car to be leaner.
Old Oct 27, 2004 | 11:24 AM
0rion's Avatar
0rion
A colder spark helps keep detonation (knock) from happening.
Old Oct 27, 2004 | 04:44 PM
tramminc's Avatar
tramminc
but isn't the power also reduced
Old Oct 28, 2004 | 12:19 AM
0rion's Avatar
0rion
I'm not expert on the subject but I'm sure someone here has more knowledge than I do. A colder plug (TR-6 for example) is usually used in forced induction applications where detonation tends to be a problem. I see some h/c guys run them too. The only plus I can see running it on a N/A car is you might be able to get away with more timing.
To i maybe wrong
