C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Need Help With Air Flow Problem
Old Nov 26, 2004 | 05:39 PM
C5USA01's Avatar
C5USA01
Default Need Help With Air Flow Problem
I have an '01 Coupe MN6 (22K miles) which has a Blackwing and Corsa Touring exhaust and X-Pipe. My car had been running fine. I took her into the Chevy dealer body shop to install a Motor City Carbon Fibrer Hood (vented on top) and Tiger Shark front fascia (looks more like the C6 front). It looks great, but upon driving her she begain stalling at lights and bucking for no reason in 5th gear. Took her back to the dealer and the Vette tech did all kind of tests and the only way he could make the problem go away was to install a stock air filter. Prior to taking the Blackwing out, he did switch MAF's and the problem was still there. As you can imagine, I wasn't too happy about giving up the Blackwing. His tests indicate that the engine is getting too much air and burning too lean. I am not a mechanic by any means, but I have never heard of anything like this. The mechanic showed me the Blackwing and it looked dirty to me, but the sensor did not indicate so. Any ideas? SHould I take my car to a tuner?
Thanks for any help.
Old Nov 27, 2004 | 03:52 PM
BlueDragon's Avatar
BlueDragon
Might be a MAF wire or even a plug wire for that much. I do my own tune. I would take it to a good tuner and ask for Scan. I could see where the HP Scan chart would help. You would be able to see everything there in chart form and replay it.
If it was runng good when it went in, it was something they distrubed. I don't buy just changing from the blackwing. could be an obstruction also. going lean says the computer saw less air through the maf Could be just running on the long term fuel trims. I suggest also looking at the Long Term and short term Fuel Tables in 3D. You would see it right away.
Old Nov 28, 2004 | 03:35 AM
FRC Tom's Avatar
FRC Tom
The shape of the Blackwing with forced air causes turbulance to the MAF.
Put a cone K&N filter on and you'll be fine.
Old Nov 29, 2004 | 04:47 PM
DTSNGIT's Avatar
DTSNGIT
Joe,
If you did not get my previous email then drop me an email to: dtsngit@bellsouth.net. I can help you over the Holidays when I'm in your area.
Mike
Old Dec 24, 2004 | 07:33 PM
C5USA01's Avatar
C5USA01
Default Air Flow Problem Fixed
I just wanted to send out a special thanks to Mike Bruce (DTSNGIT) who was able to fix my air flow problem while he was in Maryland. The Blackwing is back on my Vette and my baby is running great. Mike also tuned my wife's '03 Vert A4 while he was here. We couldn't beleive what a difference it made in acceleration. I think even Mike was surprised how fast it moved.
Mike's a great guy who is very knowledgeable. I highly recommend him.
Merry Christmas and Happy New Year to all.
Joe
Old Dec 24, 2004 | 11:24 PM
DTSNGIT's Avatar
DTSNGIT
Thanks Joe! We'll get your car fixed up before long with LS1 Edit. I promise it will run as good as the wifes................
Mike
Old Dec 28, 2004 | 05:17 PM
SANMAN1's Avatar
SANMAN1
Joe
That is real
To Need Help With Air Flow Problem
