Aftermarket Wheel Weight
VR
19.2 lbs, front; 21.4 lbs, rear --- 97-99 OEM wagon --- Source
22 lbs, front; 29 lbs, rear --- 97-99 OEM wagon --- Source
17 lbs, front; 19.5 lbs rear --- 97-00 OEM magnesium --- Source
17.5 lbs, front; 19.5 lbs, rear --- 97-00 OEM magnesium --- Source
18.08 lbs, front; 20.06 rear --- 00 OEM standard, thin spoke, high polish --- Source
17 lbs, front; 20 lbs, rear --- 00 OEM standard, thin spoke, painted, no sensors or centercaps --- Source
16 lbs, front; 20 lbs, rear --- 01 OEM standard high polish --- Source
19.6 lbs, front; 21.4 lbs, rear --- 01 Z06 forged --- Source
19.2 lbs, front; 21 lbs, rear --- 02-04 Z06 cast/spun --- Source, Source
24 lbs, 18x10.5 --- 00+ repro high polish --- Source
28 lbs, front; 32 lbs, rear --- Z06 chrome repro --- Source
23 lbs, front; 26 lbs, rear --- Z06 chrome repro --- Source
23.5 lbs, front; 24.5 lbs, rear --- Z06 Motorsports, polished --- Source
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear --- PWO --- Source
22 lbs, 18x10.5, 58mm offset, front --- HRE 545 w/clear center --- Source
27 lbs, 18x12, 74mm offset, rear --- HRE 545 w/clear center --- Source
Joe
Here is more weight specs for you with tires, wheels and combinations.Wheels
Lugnuts
1.5 oz --- OEM open lugnut --- Source
Tires
NOTE: Kumho tires are not currently differentiated between runflat and nonrunflat tires.
29.5 lbs, front; 32.5 lbs, rear --- Goodyear EMT, stock size --- Source
27 lbs, front; 33 lbs, rear --- Bridgestone S03's, stock size --- Source
26.4 lbs --- Goodyear GS-C 275/40R17 --- Source
12 lbs, 275/40x17; 15 lbs, 315/35x17; 16 lbs, 305/30x18 --- Hoosier A3S03 --- Source
28 lbs, 275/40x17=28lbs; 30.5 lbs, 315/35x17 --- Goodyear ZR "S" Rains --- Source
25 lbs, 275/40x17; 28 lbs, 315/35x17 (shaved to 6/32") --- Goodyear GS CS --- Source
23lbs, 265/40x17; 24.5 lbs, 275/40x18; 25.5 lbs, 295/35x18 --- Goodyear F1 GS CS --- Source
27 lbs, 265/40R18; 28 lbs, 315/40R18 --- Goodyear GS F1 SC --- Source
25 lbs, 255/40R17 --- Bridgestone Potenza S02 --- Source
27 lbs, 275/40R18 --- Bridgestone Potenza S02 --- Source
29 lbs, 285/30R18 --- Bridgestone Potenza S02 --- Source
30 lbs, 285/30R18 --- Bridgestone Potenza S02 --- Source
30 lbs, 295/30R18 --- Bridgestone Potenza S02 --- Source
29 lbs, 295/35R18 --- Bridgestone Potenza S02 --- Source
28 lbs, 245/45R17 --- Kumho Ecsta ASX --- Source
28 lbs, 245/45R17 --- Kumho Ecsta 711 --- Source
29 lbs, 245/45R17 --- Kumho Ecsta Supra --- Source
25 lbs, 245/45R17 --- Kumho Ecsta MX --- Source
32 lbs, 245/45R17 --- Kumho Ecsta MX --- Source
26 lbs, 245/45R17 --- Kumho Ecsta Victoracer V700 --- Source
30 lbs, 265/40R17 --- Kumho Ecsta Supra --- Source
32 lbs, 275/40R17 --- Kumho Ecsta ASX --- Source
20 lbs, 275/40R17 --- Kumho Ecsta MX --- Source
36 lbs, 275/40R17 --- Kumho Ecsta MX --- Source
25 lbs, 285/30R18 --- Kumho Ecsta V700 --- Source
TBD lbs, 295/35R18 --- Kumho Ecsta ASX --- Source
30 lbs, 295/35R18 --- Kumho Ecsta Supra --- Source
20 lbs, 275/35R18 --- Kumho Ecsta MX --- Source
31 lbs, 295/35R18 --- Kumho Ecsta MX --- Source
26 lbs, 305/30R18 --- Kumho Ecsta V700 --- Source
28 lbs, 315/35R18 --- Kumho Ecsta V710 --- Source
30 lbs, 335/30R18 --- Kumho Ecsta V700 --- Source
Wheel & Tire combined weight
45 lbs, front --- 97-00 OEM magnesium w/Nitto 275/40-17 (1/2 tread) --- Source
50 lbs, rear --- 97-00 OEM magnesium w/Yoko 295/35-18 AVS Sport non-runflats --- Source
47 lbs, front --- 97-00 OEM magnesium w/OEM 245/45-17 runflats --- Source
53 lbs, rear --- 97-00 OEM magnesium w/OEM 275/40-18 runflats --- Source
50 lbs, 17x8.5, 58mm offset, front --- PWO w/OEM 245/45-17 runflats (1/2 tread) --- Source
VR
