Clutch Kit suggestions!!!
Old Jan 27, 2005 | 09:27 PM
T.J.'s Avatar
T.J.
Default Clutch Kit suggestions!!!
Hey everyone, I'm needing to replace my clutch and I'm looking for recommendations. My 97 has basic mods air intake, exhaust nothing major, so what to buy? I've seen some from WCC, but which one. I was thinking the Stage one SPEC performance clutch or the ZO6 clutch assembly. Any suggestions would be appreciated.
T.J.
Old Jan 27, 2005 | 09:38 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
with those mods I would go with the Z06 clutch. I will be by far the most streetable and less error prone.
Old Jan 27, 2005 | 10:17 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Old Jan 28, 2005 | 11:10 AM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
I have the LUK clutch from A&A with the alum fly. I love it and it drives like stock. It even holds up to 4500 rpm launches in second with my hp.
Old Jan 28, 2005 | 11:56 AM
Jeff Jeff's Avatar
Jeff Jeff
I have the LUK and have had nothing but problems with it. It was off 16 grams from the factory, now my gears are grinding when shifting and I get an awful noise sometimes when the clutch is pressed in.
I would recommend keeping your stock flywheel and going with the Z06 clutch. At your power levels, there is no reason to subject yourself the possibility of endless problems like I have.
Old Jan 28, 2005 | 12:24 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
with those few mods i would seriously consider the z06 clutch, i would still be running mine, but after the blew the tranny on the dyno i went ahead and threw in a Spec Stage II, i love it, although it does feel quite a bit different from the z06 clutch.
To Clutch Kit suggestions!!!
