leaking water pump?
Old Jan 28, 2005 | 11:44 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Default leaking water pump?
Hey guys, yesterday my belt started chirping loudly and a low coolant warning came on. Sure enough the water is coming fairly quickly out of the bottom of the water pump. After i handle a few more things for school, i'm going to head out and start puling it off to see what's really broken.
Is this a common problem with these cars?
How big of a job am i looking at for chaning the water pump?
BTW, i've go 104,000miles on the car, although the pump was re-sealed almost 2 years ago.
Thanks, Chris
Old Jan 28, 2005 | 12:20 PM
Silver98's Avatar
Silver98
The job is pretty easy. Pull the belt and the ACbelt then replace the h2o pump. While you're at it, maybe change out the belts and check the idler pulleies for any signs of fatigue.
Old Jan 28, 2005 | 01:18 PM
Stangkiller
Thanks for the responce! What are my options as far as water pumps? Is an electric pump a viable upgrade at this point?
Thanks, Chris
Old Jan 28, 2005 | 02:56 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
This sucks Chris. Hope you get her fixed before next weekend.
I hope to have mine fixed for Daytona.
Old Jan 28, 2005 | 03:37 PM
Stangkiller
Whatsa the final verdict on your car? I think its just the rubber seals, i'm replacing them and reinstalling the pump i hope thats all it is!
Chris
Old Jan 28, 2005 | 07:06 PM
Stangkiller
Ok, so there's new seals in there and it's still leaking, looks like the pump needs to be replaced.
What are my options for a water pump?
Thanks,
Chris
Old Jan 28, 2005 | 07:53 PM
leaftye's Avatar
leaftye
The electric pumps don't pump as much as the stock pump, and I believe they go for around $350. Evanscooling.com has a ported stock type pump with a better impeller, and goes for $500. Evans is currently in a lawsuit with GM over a claim that GM stole their design to use reverse cooling on the LT1 engine, and it looks like they're going to win, so I'd say Evans knows what they're doing. I've heard rumors that the LS2 pump is compatible, and better.
Old Jan 28, 2005 | 08:13 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Idler Pullies
________________________________________ ____________________
[Silver98]The job is pretty easy. Pull the belt and the ACbelt then replace the h2o pump. While you're at it, maybe change out the belts and check the idler pulleies for any signs of fatigue.
I used a small thin screw driver and poped the seals on the idler pullies, cleaned off the bearings, and repacked them with grease. They were pretty dry.
Old Jan 29, 2005 | 08:37 AM
JeepTJ's Avatar
JeepTJ
Looks like the flexplate exploded. Busted the starter and the bell housing. We are going pull the back end out of the car Thurs or Friday. Hope to make Daytona in the Vette.
Old Jan 29, 2005 | 02:45 PM
Stangkiller
Awesome hope to see it there as well....Who's doing your work?
Chris
Old Jan 29, 2005 | 02:46 PM
Stangkiller
Awesome, thanks for the insight, it looks like i can order a stock pump at the local discount for 175 dollars, i'm planning on calling around in a bit.
Chris
Old Jan 31, 2005 | 06:43 PM
JeepTJ's Avatar
JeepTJ
Chris
Bob (The Violator) Moss is coming down from Knoxville on Wed. We, he will start working on her Thursday. And we will be at Daytona early Saturday.
I'm thinking they must have run out Vettes for him to take apart in Knoxville.
Old Jan 31, 2005 | 08:45 PM
Stangkiller
Awesome, he put my original LS1edit on my car!
Chris
To leaking water pump?
