need vpb control arm bushing install help
Old Feb 1, 2005 | 12:14 PM
RAFTRACER's Avatar
RAFTRACER
Originally Posted by Nick Williams
I did a set of the VBP on Nitro C5's car. I just cut one side of the bushing flush with the control arm and then used a press to get them out. Once all the control arms are of the car, changing the bushings is the easy part.
Thats exactly how to do it
Old Feb 1, 2005 | 07:24 PM
tcmc5's Avatar
tcmc5
Exactly how I did it. No sweat.
Old Feb 1, 2005 | 07:37 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
make sure you don't bend the arms pressing them, use a spacer in between.
Old Feb 1, 2005 | 07:41 PM
RAFTRACER's Avatar
RAFTRACER
HUH???? you only press on one bushing at a time
Old Feb 13, 2005 | 09:49 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Update: got one side of the fronts done last night. Followed VP&P's instructions to cut off 1 side with a sawzall, then press the bushing out with a ball joint press. Got the press from Harbor Freight for $19.99 and it works perfectly!!
Old Feb 13, 2005 | 10:43 AM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Originally Posted by Shinobi'sZ
You have done more dudes maybe.
That was completely classless
You should really watch who you try and discredit. Maybe learn a little about who you are talking too before trying to school them.
As stated Danny is a very highly skilled Vette guy. Done some of the best suspension set ups around and has a little driving skill to go along with it.
Lets see multiple great set ups for others plus driven the car he set up to what, 7 national championships ......
Old Feb 15, 2005 | 09:27 PM
silverz06vette's Avatar
silverz06vette
Was this the tool that you got?
http://www.harborfreight.com/cpi/cta...emnumber=38335
Thanks!!
Old Feb 16, 2005 | 08:34 AM
dmtnt's Avatar
dmtnt
Thanks!!
Replied to your PM as well.
Old Feb 28, 2005 | 04:19 PM
wicked96's Avatar
wicked96
Raftracer, have you any idea why you shouldnt run the Poly Bushings on the lower rear control arms on a C5 street car?
MTI out of Atlanta is putting the bushings on the upper only and stating that lowers are not recomended for street use.
Old Feb 28, 2005 | 06:40 PM
RAFTRACER's Avatar
RAFTRACER
No idea, I would know why they wouldn't put them in the rear uppers, but not the rear lowers. The upper ones are much more prone to squeaking and require more maintainence ( lubrication). It all depends on what you are willing to deal with. I wouldn't think twice about putting them in a street car, but I may be biased
Old Feb 28, 2005 | 09:18 PM
wicked96's Avatar
wicked96
Thanks again!
Old Feb 28, 2005 | 10:29 PM
dmtnt's Avatar
dmtnt
Since this thread is still alive, I'll add a couple of tips since I've been working on this recently:
1. Use the ball joint tool to push the bushings out of the bore a bit before cutting. This reduces the chance of accidentally cutting into the control arm
2. Use some WD-40 to clean out the bore on the control arm before installing the new bushings
3. I didn't have much luck trying to tap the round end plates onto the lower arms with a hammer as the instructions show. I used a long bolt, nut and some washers, ran it through the arm, bushings, and plates, then used an impact gun to tighten it down and seat the plates.
4. On the rears, you don't need to cut any of the bushings except one on the lower control arms. The rest push straight out assuming you have the Harbor Freight ball joint tool or comparable.
Old Mar 1, 2005 | 10:25 AM
  #33
wicked96's Avatar
wicked96
Thanks for the tips. I plan on doing my rear this weekend!
Hope this helps keep the rear planted, I have some serious wheel hop...
Old Apr 16, 2005 | 12:28 AM
  #34
silverz06vette
Any other tips?
Got my kit today from VBP, yes they did have them in stock.
I'm going to do the fronts first, then the rears when we pull everything out to change the clutch.
Old Apr 16, 2005 | 09:28 AM
  #35
RogueVette's Avatar
RogueVette
Any other tips?
We followed Raftracers tips and it went very quickly. Of course I had beaten my stock bushings down so badly that I could nearly push them out with my thumb
Old Apr 17, 2005 | 05:21 PM
  #36
silverz06vette
Does the front spring have to be removed to get the lower arms out?
Here is some info I found from a non-GM manual:
Raise and support the vehicle. Refer to Vehicle Lifting.
Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation.
Using the J 33432-A, remove the front transverse spring. Refer to Front Transverse Spring Replacement.
Disconnect the electrical connector from the wheel speed sensor.
Disconnect the real time damping electrical connector from the shock, if equipped.
Remove the shock absorber from the lower control arm.
Remove the stabilizer shaft link from the lower control arm.
Loosen the ball joint stud nut but do not remove the nut.
Using J 42188 separate the lower ball joint stud from the steering knuckle.
Remove J42188and the ball joint stud nut (2).
Remove the ball joint stud from the steering knuckle.
Mark the position of the cam bolts for orientation when installing.
Remove the cam bolts, washers, and nuts retaining the control arm to the crossmember.
Remove the lower control arm from the vehicle.
Old Apr 17, 2005 | 09:22 PM
  #37
John Shiels
no reason to remove it
Old Apr 18, 2005 | 07:44 AM
  #38
silverz06vette
Thanks John!
Will try and get all 4 arms off the front today. That way I can take them into work and battle with them to get he old bushings out.
Old Apr 19, 2005 | 10:20 AM
  #39
silverz06vette
Here is a decent how to:
http://www.corvettefever.com/howto/33162/
Got the rubber out of the rear arms today fronts yesterday.
Yesterday I used a high-speed wheel to cut the rubber, what a freakin' mess that was. Today I used a utility knife and cut the rubber off then used an arbor press. I think this worked much better.
