Getting the C1232 H C
Old Jan 29, 2005 | 06:59 AM
Vince99FRC's Avatar
Vince99FRC
Default Getting the C1232 H C
This is coming up on start up even after I try and clear the code. I even disconnected the battery and it just pops right back up. What baffles me is I never disconnected the front wheel sensors to do the clutch install. Just the rear and I connected everything back up. I disconnected the front and reconnected and the code will not go away. Any suggestions what could have happen? I doubt if the wheel sensor decided to take a crap while I was doing a clutch install. I need some directions on what to check.
Old Jan 29, 2005 | 09:04 AM
99blackFRC's Avatar
99blackFRC
might be the wiring harness and not the sensor itself.. try swapping left to right and see if moves? I've heard this suggestion before, might want to give it a try..
Old Jan 29, 2005 | 06:04 PM
Vince99FRC's Avatar
Vince99FRC
I think the connection going from the frame is disconnected. I will check this on Monday. I was told if the sensor was bad you could still clear the code, but once you get to 18mph the car will throw the code again. That's not the case with mine. I have an open somewhere because you cannot clear the code at all. As soon as you turn the key the code is there and the service abs, service traction control, etc., comes on..
To Getting the C1232 H C
