Need some help with codes please!
Old Jan 29, 2005 | 03:37 PM
rudolph schenker's Avatar
rudolph schenker
Default Need some help with codes please!
My check engine light came on, so I checked the DIC and the following codes came up, PO420,PO430. The maual said TWC system low efficiency bank 1-A 2-A. Anybody know what these mean, and what I need to do? Thanks in advance!
Old Jan 29, 2005 | 07:02 PM
Nick 02 Z06's Avatar
Nick 02 Z06
A member TXNC5 PM'd me this and it is invaluble information.
Go here www.gearchater.com
For PO420/430 Here http://www.gearchatter.com/viewtopic10342.php
Good luck! I hope this is what you need!
Old Jan 29, 2005 | 10:18 PM
djengr's Avatar
djengr
Default P0420 & P0430
I have the same codes coming up on my 96 tahoe. The guys at autozone say inefficient catilitic converter. I have not changed the cats on the tahoe yet, just run with the light on for now. The code numbers are the same discrip as you have. Tahoe has 140K miles. If yours has low mileage, try to clear the code and see if it comes back. Good luck
Old Jan 30, 2005 | 12:09 AM
rudolph schenker
Thank you "Nick 02 Zo6" and "djengr" for the info! I just installed long tube headers and a GHL exhaust and have yet to get it Dyno-tuned, so I suspect the air-fuel ratios are a little off and might have caused this code.
Old Jan 30, 2005 | 06:20 AM
Nick 02 Z06
Roger that, I hope you get it worked out! BTW, love that Avatar! Blackout! Great album!
To Need some help with codes please!
