Stock Rotors are Directional.
Old Jan 30, 2005 | 10:48 AM
jim2527's Avatar
jim2527
Default Stock Rotors are Directional.
Just a little FYI for all of you who may not know.
I decided to put Z06 brake pads on my '03 coupe. As recommended by the forum I picked up new rotors from NAPA. When I was at the counter the guy said, "you need left or right or both?" I said, "they're the same." He said, "they have different part numbers." So, whatever, I went home with new rotors. The difference is in the cooling vanes. They are angled versus perpendicular. So I do the brake job and install the rotors.
For whatever reason I had the wheel off and noticed the vanes were angled so they wouldnt scoop are in. Dam, so I swapped the rotors real quick. Well, the next day I'm doing a rotor/caliper paint test (more on that later) and notice the factory 'right' stamping and look at the vanes. They point the other way!!!! It turns out I had them installed correctly the first time. Well, I'm off the swap then again. It turns out the vanes are designed to pull are in from the center area near the hub versus pulling air in from the outer rim. Oh well.
Old Jan 30, 2005 | 10:54 AM
Mighty-Mouse's Avatar
Mighty-Mouse
Ignore the holes, it really doesn't matter what direction they rotate in. The pictures are to show the direction of the internal vanes and the slots on the face of the rotor. Those must rotate in the proper fashion for the rotor to be effective.
http://forums.corvetteforum.com/show...post1549577331
In street driving it's not that big a deal. But on the track you will see 10-15% higher temperature on the rotors going in the "wrong" direction.
Old Jan 30, 2005 | 10:57 AM
VetteTech81's Avatar
VetteTech81
This is a GOOD note for the Do it yourself guys. Even pro's from time to time make mistakes. This is a good tip for everyone to remmber.
-=Rick
Old Jan 30, 2005 | 11:28 AM
BBates's Avatar
BBates
When I did mine I noticed that they were different part numbers. So, I only did one side at a time and compaired it to the stock stamped rotor that I was removing. I did not look right to me at the time either but after checking I found out the same thing you did. I was just happy that I did not have to take it all apart again.
Old Jan 30, 2005 | 11:30 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
On the C5/Z06 (stock or OEM replacements) they are directional. I've read that GM has made all the C6 rotors the same so one side will be backwards on the C6.
Easy way to tell if they are correct on the C5/Z06 as you put them on is to look straight down at the top of the rotor. The vanes should "point" rearwards.
You can visualize this looking at the first pic posted by Mighty Mouse above. That rotor would be a driver's side rotor being viewed from outside the car. You can see the top of the vanes pointing right, or backwards towards the rear of the car.
The reason for this is that the vanes act as a centrifugal pump as they rotate and pull air from the center out to the outer edge.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 30, 2005 | 12:49 PM
coast7's Avatar
coast7
I just did some brake work yesterday and noticed my stock rotors were stamped with LR, RR, etc. Nice to know!
coast7
Old Jan 30, 2005 | 01:14 PM
C66 Racing's Avatar
C66 Racing
coast7
That's correct for those bought directly from GM, but aftermarket OEM rotors such as those bought from NAPA do not have the same marking, which makes it easy to get them on wrong.
Old Jan 30, 2005 | 07:27 PM
H82GOSLW's Avatar
H82GOSLW
Plan on doing this very activity in the near future. Thanks to all who've posted for the info!!!!
Old Jan 30, 2005 | 07:53 PM
SLO VETTE's Avatar
SLO VETTE
this is a really helpful post, thanks for making it. bookmarked!
Old Jan 30, 2005 | 08:11 PM
Morzoff's Avatar
Morzoff
Great infor, I will be installing mine next week
Old Jan 30, 2005 | 11:42 PM
Richin Chicago's Avatar
Richin Chicago
Just to expand on this a little. A rotor should never blow air towards the wheel bearing. This can ruin the wheel bearings in a very short period of time during hard brake usage. The heat MUST be evacuated out the top of the rotor not down towards the center. As you have observed, and the drawings show, the fins point backwards and do not "scoop" the air when the wheel is moving forward.
It would also be couterproductive to try to force air to the center as that would be fighting centrifugal force.
I label each rotor as soon as I get them to make sure I don't get in a hurry and put them on the wrong side.
Next time you are at a car show with a bunch "show rotors" feel the vanes and see which way they point. I, usually, manage to find a couple of cars with the rotors on the wrong side!
Also have found some on tech inspects for track events.
Old Jan 31, 2005 | 01:16 PM
2kbluestreak's Avatar
2kbluestreak
Several C6 owners on the C6 side of the forum are really pizzed at Chevy because they have the same exact rotor on the left front and the right front. They probably wouldn't have noticed if it weren't for the spiral cross-drilled hole pattern. Some have been told by Chevy that it really doesn't make much differance for a street driven car. Whatever else they also told owners, they are not getting the correct rotor for one wheel. What was that book by DeLorian, "On a clear day you can see General Motors"?
Old Jan 31, 2005 | 02:39 PM
C54DAZ's Avatar
C54DAZ
OK so why is it every car I see around town has there rotors going in the wrong direction? I was starting to wonder if I put mine on backwards but they are stamped lf rf rr lr. Or are the ricers and other high performance cars rotors holes drilled in reverse direction that the fins are cast? Or is this just the new cool look, to be azz backwards?
Old Jan 31, 2005 | 04:41 PM
dkdonkim's Avatar
dkdonkim
thank you....i just checked mine, they were correct....
Old Jan 31, 2005 | 04:59 PM
VetteSiNz's Avatar
VetteSiNz
I learn something new everyday. Thanks for posting.
Old Jan 31, 2005 | 05:16 PM
ZO6vettepilot's Avatar
ZO6vettepilot
The drilling pattern doesn't make any difference, it's the inside vanes that do the work. So some may be mounted correctly, others may be mounted backwards because the owner "thought" they were correct because the drill pattern looked better. HEY... maybe that's why they wear their hats backwards, they think it cools better...
zo6vettepilot
Old Jan 31, 2005 | 06:47 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Just picture the vanes that close together spinning that fast there wouldn't be much scooping happening that's why they go the other way and create vacuum to draw the air out. That is why spindle ducts blow the air IN to the center to let the vanes pull it out.
To Stock Rotors are Directional.
Old Jan 31, 2005 | 09:50 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Think centrifugal force and you'll understand it better.
Old Feb 1, 2005 | 01:03 AM
1FUNVTT's Avatar
1FUNVTT
It's always nice to be reminded now & then on these easily forgotten or overlooked instructions. Especially when us novice mechanic don't do a brakes job too often.
Old Feb 1, 2005 | 08:00 AM
Cap'n Pete's Avatar
Cap'n Pete
Yep, it's just like having a fan on your wheels!
Now on those pictures posted, it appears that both of those slotted/cross-drilled rotors are going "backwards"? Are the internal vanes still pointed rearward like the stock ones though? Otherwise, it would seem they're not going to be working effectively?!
