X-pipes
Old Jan 30, 2005 | 11:55 AM
newsier's Avatar
newsier
5th Gear
Default X-pipes
I installed B - B Bullet pipes last year on my 04 vert.........sweet.
Naturally, there is some resonation in the car with the top up. My better half hasn't said anything but she does suffer from migrains and I do not want to be the source of a headache.
My question.........I read installing an aftermarket X pipe will reduce the resonation in the car.
Can anyone confirm or deny?
Thanks for any help.........................Glenn
Old Jan 30, 2005 | 11:58 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Get an "x" pipe. I only have experience with Magnaflow's X (before my LG's) and it completely removed the 1600rpm drone! I am pretty sure other "X" pipes will do the same.
Old Jan 30, 2005 | 02:58 PM
VETFVER's Avatar
VETFVER
I have found that an X-piple will lower the volume of sound 15 to 20%. Yes, it will lower the hum inside your car at low speeds. Out on the freeway, you should be Okay. If you don't want to turn the sound down as your first choice, add insulation to your trunk/cargo area. That is a less expensive fix than the X-pipe.
Good Luck!
Dan
Old Feb 2, 2005 | 04:55 PM
FKING1's Avatar
FKING1
Had headers and Corsa cat back then installed Bassani X which did decrease the resonance some but not a great deal.Maybe 20%.
Fred K.
Old Feb 2, 2005 | 08:30 PM
KOMPNS8's Avatar
KOMPNS8
any body else find a joke to be made in an e-mail about "installing pipe" and a "a wife that suffers from migrains"?
'sorry i just had to through that out there. i'm only joking. please take my words with a grain of salt... and a shot of tequila and lime if needed.
To X-pipes
