Sway Bars??? Hollow or Solid
Old Jan 30, 2005 | 01:55 PM
Drav1212's Avatar
Drav1212
Default Sway Bars??? Hollow or Solid
Does anyone have an opinion on which style sway bar to purchase, hollow or solid???
Old Jan 30, 2005 | 02:06 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
I have Hotchkiss and they are hollow, solid would be Alot more heavy!
Old Jan 30, 2005 | 04:42 PM
Drav1212's Avatar
Drav1212
Default YEs
I was ooking at them, they are hollow. But I also found a Co. that makes Solid sway bars. And the Front sway bar is larger than the Hotckik, but the rear sway bar is smaller.
Old Jan 30, 2005 | 04:52 PM
devo's Avatar
devo
The T1's are a little bit bigger and I do believe those are hollow. if the bars you are looking at are bigger than the T1's and solid my question is why?
Old Jan 30, 2005 | 05:05 PM
sams96's Avatar
sams96
I also have hotchkiss and I like them but I might get the T1's. Go with a hollow bar the solid bar is much heavier.
Old Jan 30, 2005 | 07:30 PM
66427-450's Avatar
66427-450
no question, hollow....C5's use hollow bars.
for the same stiffness, the bar will be significantly lighter, and lighter is good, yes?
Old Jan 30, 2005 | 08:08 PM
Mike04's Avatar
Mike04
I'm very happy with the Z06 swaybar upgrade I did. Hollow works.
Old Jan 30, 2005 | 08:41 PM
leaftye's Avatar
leaftye
In the twisting force the swaybars resist, the parts of the bar further from the center are subjected to greater forces. The further you go out, the greater the forces. The material in the middle, if there is material, does little but add weight to the part. All GM bars and the Hotchkis bars are hollow.
Eugene
Old Jan 30, 2005 | 09:02 PM
Drav1212's Avatar
Drav1212
Default Here is the Link to Solid Sway Bars
Well NOT the link, but it is the BMR Fabrications Inc. under corvette section.
Tell me what you guys think please.
http://www.bmrfabrication.com/C5.htm
Old Jan 31, 2005 | 07:20 AM
leaftye's Avatar
leaftye
The way I'm reading the replies, everyone that has replied suggests the hollow bars. I guess that's not good enough for you, so I'll give you what you want to hear:
Solid sway bars are the best! They resist sway better than hollow bars while weighing less, and they aren't as harsh either. They'll also improve acceleration and braking.
Old Jan 31, 2005 | 08:11 PM
Ls1Rat's Avatar
Ls1Rat
Depending on the price, I'd want hollow, but if it's a mega-buck differnce, I'll take solid.
Old Jan 31, 2005 | 08:24 PM
Drav1212's Avatar
Drav1212
THe price is not much different
To Sway Bars??? Hollow or Solid
