MSD Blaster Coils
Old Jan 31, 2005 | 12:17 AM
denscor's Avatar
denscor
Default MSD Blaster Coils
Has anyone thought of using these(MSD blaster Coils for the LS1/LS6) they will not be out until March 31.I wonder if you will see any increase in power?They increase voltage by 40% the cost is going to be 75 per coil! There going to have some kind of plug for a later type of controller? Just wanting to get feedback! Also i heard that coils off a 6.0 truck were hotter then LS1 coils.
Old Jan 31, 2005 | 05:47 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The only thing I heard was that they are going to be a waste of money for the C5. I'm not sure if that is true or not. I've always used them on my Mustang's and had good results.
Old Jan 31, 2005 | 09:19 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Power probally not, Hotter spark probally.
On the LS1 its a waste of money, thats why companies like Jacobs and such have no "stright" system for the LS1. That I know of anyway.
Old Jan 31, 2005 | 09:42 AM
ZO6vettepilot's Avatar
ZO6vettepilot
If the LS1 or LS6 is still normally aspirated there is no significant gain at all. However, if the engine is supercharged, turbocharged, using abnormally high compression ratios, or high NOS loads, then there may be some benefit to ensure there are no misfires. The significancre of the MSD is in it's name... it fires the plug multiple times to ensure a full ignition and burn under less than optimal conditions such as when very high cylinder pressures are present, which could inhibit a good spark jump.
The LSx series engines seem to have a pretty good ignition right from the factory.
Z06vettepilot
To MSD Blaster Coils
