Need input on a Supercharged car Cam?
Old Feb 1, 2005 | 12:12 AM
3XBlack6spd's Avatar
3XBlack6spd
Default Need input on a Supercharged car Cam?
I am about to pull the trigger on the G1 "blower" Cam I am just curious if any of you guys with the same, or similar set up as mine have swapped out the Cam, and what you Went with? I have been told this is the best Blower cam choice, but haven't seen any real world results from guys with my set up. I have a S-trim with 28/30 pulleys 9-10lbs of boost, and The Common bolt ons, Vararam, Headers, X-pipe and Exhaust. I am currently at about 600RWHP, and wondering what to expect. I have been told 50-60 RWHP with the cam, and Valve train upgrade. I am hoping for around 650RWHP Does this sound about right? Also I really like the Loppy cam sound, and MTI is suggesting a 115 LSA, and I don't think this will be loppy enough for my tastes, Will something a little tighter like a 114 or even 133LSA be ok, or is the 115 that important for optimal HP in a Supercharged car?? Any real world input Would be Greatly appreciated!!!
Old Feb 1, 2005 | 12:28 AM
chriskaw7r's Avatar
chriskaw7r
I would stick with a max of a 115 lsa. That seems to be the max for a S/C car. Anything more and you just end up blowing alot of your boost out the tail pipe. The smaller the number the more valve overlap you get. I was affraid of the same thing with the car not having any lope. I just put in a 115lsa 218/224 .562/.567 comp cams custom grind cam in. It definantly has a lope, nothing to extreme but definantly no stock car. I also have a procharger so I was concerned about getting the right cam also. I could take a video and sound file of it if you want to here it. I gonna go out on a limb here and say everybody that wants to here it give me there email address.
Old Feb 1, 2005 | 02:51 AM
3XBlack6spd
Please send XxLiveFastxx@aol.com
Thanks.
Old Feb 1, 2005 | 04:45 AM
99SilverC5Coupe's Avatar
99SilverC5Coupe
email please and thanks....
Old Feb 1, 2005 | 09:03 AM
SideStep's Avatar
SideStep
I have a G1 on 115 LSA with +4 degrees advance...
...there is a sound file in my sig
Old Feb 1, 2005 | 01:53 PM
3XBlack6spd
I have listened to your car before, It sounds good, you can tell there is a cam, but it just doesn't have enough! That's my hang up, I wonder how mush choppier a 114 or 113 really is than a 115?
With the amount of noise my blower makes, it will be hard to even tell there is a cam if it is that discrete. You can listen in my sig.
Old Feb 1, 2005 | 06:39 PM
blown in n.c.'s Avatar
blown in n.c.
I have a 218/220 114 on my car, but I don't have a sound file. Not sure of the lift either. You can tell there is a cam in it and it is not an aggressive cam. Wingnut on here has a monster blower cam on his magnusson set up that is a custom grind from More Performance. It rocks the whole freakin car
Old Feb 1, 2005 | 07:36 PM
David Plum's Avatar
David Plum
Call Chris Padgent at comp cams he will probably say something like 228 232 @ .050 580 595 Trust him
Old Feb 1, 2005 | 08:11 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Listen to my exhaust...
VR
Old Feb 1, 2005 | 08:39 PM
3XBlack6spd
I went with the G1, which is a Comp cam actually, and yes it is 228/232 .588 .575. 113lsa MTI has a good rep for the blower cam, thats why I chose them.
To Need input on a Supercharged car Cam?
