I have an 03 Z06. Did they come with 3.15 or 3.42 gears? (Doh!)
Is it best to replace the full differential unit for the hardened output shaft? Or, would I be okay changing gears only? I'm thinking 3.73s or 3.90s with about 520 rwhp.
3.42 in the ZO6. All these units 3.73, 3.90, 4.10 are rebuilt aftermarket units so you can send your rear to be rebuilt or purchase another unit to swap in. Entirely your choice. Most of us donot have the specialty tools to swap the gears in the housing. Bob
You should have 3:42 gears, Just change the gears and I would go with 4:10's. I did last year in my 97 coupe 6 spd with 02 Z-06 motor and LOVE em'! Still cruises at about 1900 to 2000 rpm at about 75-80. Perfect, don't know why anybody would go with something less, chuck
You won't be able to just swap out the ring and pinion yourself. Need expensive tools. You can however, take the diff out and bring it to the right place. Probably looking at around $250-300 for someone to do it. Or, you could send your diff to DTE and they will really hook you up.
not 100%... but close. Getrag made a 3.73 unit. It's quite expensive though ($2000). I think that is why most go with internal gear swaps instead of buying the entire 3.73 carrier.
Not 100% positive (I have a Coupe) but I think I remember reading somewhere that the 4.10s might be too high. So I would definitely suggest looking into it further.
The 4.10's will be weaker than the 3.42's. This is just due to the teeth count/size. The teeth are smaller because they ring is smaller.
It is said that expensive tools are needed to do a gear swap but the service manual does not mention anything out of the ordinary. It seems like it could be done like any other gear swap, although if you have not done a gear swap before I would not recommend the Getrag as your practice platform.
The teeth are NOT smaller and the ring gear is also NOT smaller......... I'm not sure where this came/originated from, but it is COMPLETELY inaccurate.
Sounds like the words from the LS1.com forum when referring to camaro diffs. I ask that same question when I moved up to my vette and was told they are totally different rears. My guess anyway.
DTE, I need to contact you and see about some gears
Alright, this may be inaccurate, I may have mis-stated it. I did not mean that the diameter of the ring is smaller but that since there are more teeth (at least on the pinion) so they cannot be as deep, but I believe it is true that 4.10's would not be as 'robust' as a numerically smaller ratio simply due to the multiplier. Correct? Or BS again? I will defer to the experts.
