MAF Bad or do I need a Tune?
1. Would these parts cause that much difference in airflow? By the way I am running with a Donaldson Blackwing airfilter assembly, but stock MAF with Screen removed. Never had a problem before the body mods. MAF was cleaned when the problem first happened (no dice)
2. Could the RAm air being causing turbulance? I havnt tried to ducktape off the inner nostrils to see if that makes a difference. I basically bought the hood for looks, not performance.
3. If the MAF is bad, how do I know?
4. Is re-tuning the answer?
Thanks all for your input. I am a new corvette owner and new to Corvette Forum. It is great to be here.
Bryan
Did you remove the screen from the MAF? If I recall the last year they made screens for the MAF was 2000, after that year no screens were put on the MAF.
My MAF went bad after 15,000 miles when I removed the screen from my 2000. I currently purchased a used one with a screen on it.
I would check to make sure the connectors are plug in correctly. You should ask them if they removed the MAF while working on your car. If you touch the MAF connectors with your fingers you will cause damage to the sensor as I read here on the forum. you can also buy some electrical cleaner from any auto parts store and spray it and see if that helps the problem or solves it. If you keep getting those codes you have a bad MAF.
If you have a good buddy with a vette that can switch the MAF for you a let you drive it to see if the MAF is bad that will save you money.
Or you probably need another tune as last resort. Start cheap and go from there.
Regards,
Jesus
Regards,
Jesus
