Stock airbox how is it mounted...?
Old Feb 3, 2005 | 01:12 PM
Hall1836's Avatar
Hall1836
Default Stock airbox how is it mounted...?
What holds the stock airbox in place is it held in place by the air bridge only? Does it mount to the radiator surround? Any pictures showing stock mounting points. Thanks
Old Feb 3, 2005 | 01:29 PM
lost's Avatar
lost
In a sense you are correct, with the lid off the airbridge is the only connecting point. On the lower front of the lid there are two holes with rubber grommets.Two prongs go thru those holes and grommets to hold the whole assembly in place. After loosening the two filter hold down straps and removing the filter, reach down and pull the lid toward the rear of the car to free it from the the prongs. Prongs may not be the right word, but thats it in a nutshell..
Old Feb 3, 2005 | 01:39 PM
Hall1836's Avatar
Hall1836
I see the two holes for the "prongs" but don't see where the prongs would be, are they on the surround that goes around the radiator? The back of the airbox rests against this surround correct?
Old Feb 3, 2005 | 04:10 PM
Hall1836's Avatar
Hall1836
No other responses necessary, now know where it goes and needed some parts (the Prongs) which have been ordered from chevy.
To Stock airbox how is it mounted...?
