Lifters
Old Feb 3, 2005 | 09:35 PM
pelle's Avatar
pelle
2nd Gear
Default Lifters
Does anybody know if I have to remove the heads on my 1999 FRC to replace the lifters
Old Feb 3, 2005 | 09:38 PM
SinCity-Z's Avatar
SinCity-Z
Yes! The heads have to be removed. Time to buy a Heads and Cam package.
Monty
Old Feb 3, 2005 | 10:18 PM
Patches's Avatar
Patches
You can see the lifter guides above the cylinders in this shot. The heads span the lifters as well as the cylinder bores so they must come off to remove the lifters.
Old Feb 3, 2005 | 10:20 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Well, the guys who replied above are HALF right. You could remove the lifters the way I did:
Pull the cam out without supporting the lifters, then fish them out of the oil pan for the next 3 hours....
OK, all kidding aside, Patches and SinCity are right... pull the heads, but do this BEFORE you pull the cam
Old Feb 3, 2005 | 11:06 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
After you spend 3 hours fishing them out the oil pan then you could spend another 5 hours trying to reinstall them thru the camshaft bore
Old Feb 4, 2005 | 12:04 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Monty
Old Feb 4, 2005 | 02:50 AM
pelle's Avatar
pelle
2nd Gear
Thanks everybody for quick and informative replies
To Lifters
