problem:harmonic balancer
Old Feb 4, 2005 | 06:48 PM
billy1's Avatar
billy1
Default problem:harmonic balancer
i am having trouble with my harmonic balancer i know of two more people that are having the some problem is this a common defect and im also wondering if this could cause any internal engine damage could you please give me some info of this stuff thanks
bill owen
Old Feb 4, 2005 | 06:58 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Internal? Interesting question.
Hopefully Evil-Twin or Patches wil chime in soon.
Old Feb 5, 2005 | 12:53 AM
chriskaw7r's Avatar
chriskaw7r
bill owen
Whats the problem
Old Feb 5, 2005 | 01:05 AM
vetterlatethannever's Avatar
vetterlatethannever
Originally Posted by chriskaw7r
Whats the problem
Yeah, what's the problem? Is it the wobbly pulley?
Old Feb 5, 2005 | 01:38 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If the damper is wobbling it needs to be fixed, it won't necessarily cause internal damage right away but over time the damper will get worse which could lead to premature bearing failure or at worst the damper can completley fail and well ....lets just say the results will be very ugly
Old Feb 5, 2005 | 11:28 AM
waymirec's Avatar
waymirec
I had mine fall off while driving on the highway. Wasn't pretty. In the end there wasnt any internal damage to the engine but it still wasn't pretty. Big pucker factor when it happened. Luckily it happened while still under warranty.
Old Feb 5, 2005 | 12:46 PM
billy1's Avatar
billy1
its wobbling im going to the chevy dealer on monday
Old Feb 5, 2005 | 12:50 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Is it under warranty? If not it'll be like 400 to fix. I had to have mine replaced like 2 times. The second was a part defect. I think it's slowly starting to act up again too. I wonder if it'll be better to get like and ASP pulley?
Old Feb 5, 2005 | 01:07 PM
billy1's Avatar
billy1
yea its under warrenty ive had to pay around 3000 dollars so far and ive only put 16,000 miles on its got 38,000 miles on it already
Old Feb 5, 2005 | 01:33 PM
corvettebob1's Avatar
corvettebob1
bill owen
Only a broken crankshaft!
Old Feb 5, 2005 | 03:48 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
If it's wobbling, get it to the dealer quick. If left unrepaired it can cause internal engine damage. Not the least of which could be a new crankshaft, oil pump, etc.
Old Feb 5, 2005 | 07:29 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
Be sure to pin it while you have it apart. That should prevent recurrences.
Old Feb 5, 2005 | 08:22 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You were very lucky, a forum member (I can't remember who) lost his damper and broke his crankshaft.
Old Feb 5, 2005 | 08:39 PM
Joshboody's Avatar
Joshboody
how do you know if your balancer is wobbling? I was under the car yesterday when it was running, and thought my balancer was wobbling. But after some thought, remembered that the balancer bolt spacer could be a little off center giving the appearance of a wobbling balancer. any input??
by the way I was under the car looking for a power steering leak. i'm hoping it's just the cap, but very hard to determine so far. anyone ever heard of a c5 leaking power steering fluid?
Old Feb 6, 2005 | 05:01 PM
TGBEATY's Avatar
TGBEATY
Perfect time to do a cam change....thats what started my mod fever... a stupid wobbly balancer
Old Feb 6, 2005 | 11:25 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Mine came off at the Runoffs last year and resulted in the loss of the motor. Among the many problems this can cause, there is an oil seal right behind the balancer than the balancer holds in place. Loss of oil pressure at high rpm is not a good thing.
I learned a hard lesson in my case. That lesson being, that if you take the balancer off for any reason, it doesn't stay on very well anymore. I found out after the fact, that most SCCA T1 teams use red locktite on the bolt that holds the balancer in place, though the service manual doesn't call for it. As mentioned above, others have had it pinned.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 7, 2005 | 03:27 AM
fastcop_c5's Avatar
fastcop_c5
could this cause any problems with the waterpump by any chance?
To problem:harmonic balancer
Old Feb 7, 2005 | 05:30 AM
David426's Avatar
David426
What does it mean to have it "pinned"?
Old Feb 7, 2005 | 04:55 PM
FRISKY's Avatar
FRISKY
The stock balancer and crank isn't keyed together. It uses a taper fit and is held in place by torque from the crank bolt.
"Pinned" means it has had two holes/keyways cut into the parting line between the crank and balancer. You use two stainless steel pins in those holes/keyways to keep the balancer from being able to rotate on the crank, which, if allowed to rotate, causes the crank bolt to unscrew, which in turn lets the balancer walk off the end of the crank and tear up expensive stuff...
Old Feb 12, 2005 | 08:44 PM
billy1's Avatar
billy1
they havent been able to get it into the chevy dealer yet they had to order the part and thanks for all the info guys thank god i caught this before it got worse
