What Octane is safe in a C5?
Old Feb 5, 2005 | 08:46 PM
5.0_CJ's Avatar
5.0_CJ
Default What Octane is safe in a C5?
I'm just curious, I've been using premium, but 32 dollar tank fills are kicking my ***, Anyone have any experience, the vette has a knock sensor, so at worse you would loose power, however, what octans have you experimented with? 87-89-91-93 ? I've been using 93.
Old Feb 5, 2005 | 09:04 PM
PDQC5's Avatar
PDQC5
around my place here in Cali the highest octane from the pump is 91. If I am going on a long road trip I fill up with 89, never have tried 87.
Old Feb 5, 2005 | 09:07 PM
ROJ#79's Avatar
ROJ#79
89 octane works fine for normal driving!
Old Feb 5, 2005 | 09:23 PM
SilverBulletZ06's Avatar
SilverBulletZ06
93 Only!
Old Feb 5, 2005 | 09:27 PM
Tsab's Avatar
Tsab
Personally, I wouldn't use less than 91 octane if possible.
Old Feb 5, 2005 | 09:46 PM
RandW's Avatar
RandW
I use premium only, what are you really saving? At $.10 a gal and 20 gal. it's only $2
Old Feb 5, 2005 | 11:30 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
....exactly.......You own a vette and you want to be cheap with the fuel it needs to run right ?......
Old Feb 5, 2005 | 11:41 PM
Nick 02 Z06's Avatar
Nick 02 Z06
Pop open your gas door and look at the bottom of the door. It says, "Premium Recommended." Owners manual also says Premium.
For what it's worth, the gas in Arizona where I live really blows and like California it only goes up to 91 octane. I filled up and put a bottle of octane boost in and my average fuel economy went up .5 within 40 miles today. Keep in mind that this even occured with me stopping and easing out of first then power shifting through fourth at my shift light, 5 different times during that 40 miles.....
My car just seems to run better and get better gas mileage the higher octane I run.
Doesn't make sense to me to own a Corvette and cripple it by running low grade fuel.
Old Feb 5, 2005 | 11:52 PM
Dark-Knight's Avatar
Dark-Knight
93 if you can get it, cheap gas = cheap performance
Old Feb 5, 2005 | 11:54 PM
JETZ's Avatar
JETZ
You're driving a 50K performance car, but want Honda gas milage. Well, get a Honda.
Old Feb 6, 2005 | 02:29 AM
GrayC5's Avatar
GrayC5
I use 91 octane or sometimes higher.
From the 2003 Owner's manual:
Gasoline Octane
Use premium unleaded gasoline with a posted octane of 91 or higher for best performance. You may also use middle grade or regular unleaded gasoline rated at 87 octane or higher, but your vehicle’s acceleration may be slightly reduced. If the engine octane is less than 87, you may get a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you might damage your engine.
Old Feb 6, 2005 | 05:24 AM
Joe C's Avatar
Joe C
correct me if i'm wrong, but i think there's a federal law or something, that says the manufacturer cannot sell a car that won't run on 87 octane. it may not run at peak performance, but at normal operating conditions, it will run "OK" . a friend of my accidentally filled up her '97 with regular. we were coming back from carlisle, and the car seem to run just fine at normal driving conditions. i typically use 89 octane for my '85 driver, and when i had my y2k coupe i usually ran 89. as for my z06, haven't ran anything but 92-93 octane (yet). there are a lot of people that relate octane to gas quality - they will drive out of their way for 93-94 octane thinking it's a better gas. lets face it, unless you are racing and need that extra edge, 89 is just fine for normal driving in a computer controlled corvette.
Old Feb 6, 2005 | 06:45 AM
Z0SLIK's Avatar
Z0SLIK
Originally Posted by SilverBulletZ06
93 Only!
Old Feb 6, 2005 | 07:59 AM
naturalgas's Avatar
naturalgas
I thought the higher octan or better fuels also clean injectors better i have always used amaco gold which has been bought by bp i talk to a fuel delivary guy and was told most all fuels come from the same place and it was the additives that was diff, but he tols gold was shipped on separate container and was a better fuel i use it in all my cars that require preium fuels and have never had injector problems my 2cents
Old Feb 6, 2005 | 10:52 AM
corvettefrance's Avatar
corvettefrance
The LS1 or LS6 do not have a very high compression ratio like some european cars.
Plus the car has a knocking detection.
Any gas normally work fine.
If you want the maximum performance the 91 is the one.
Going higher is wast of money unless you modified your car and increase the compression ratio.
Old Feb 6, 2005 | 10:59 AM
Shall's Avatar
Shall
St. Jude Donor '05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-‘16-‘17
Tried 92 and 93 in our C4 because 94 wasn't always available on trips. Ran fine, but reduced gas mileage (or something did during those tests!). For the few bucks difference, we ran 94 and didn't think much about it. I am assuming the C5 will react the same.
Don't feel too bad, our tank fills are closer to $45.
Old Feb 6, 2005 | 06:40 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
It will run just fine on 87 and is perfectly safe to use... It will NOT harm your car/motor. This has been discussed here on the board before.
BUT, you will most likely get a lil' more power with a higher octane fuel due to the computer running more timing. The computer will pull out timing if it detects pinging/detonation. You have less of a chance of ping on higher octane fuel.
Octane slows the burn of fuel and makes it less volatile. Technically speaking (with combustion engines, for max perf), you want to run the lowest octane possible without "any" detonation (inaudible or audible).
To What Octane is safe in a C5?
Old Feb 6, 2005 | 08:20 PM
5.0_CJ's Avatar
5.0_CJ
Good arguments in here, what happened seems to be the general idea I had. Seems like 87 will do just fine for normal driving to and from work. I understand the whole "wtf, a vette and your bitching about gas prices" Well, if I can some some money going to and from work, I'll do it... I Drive about 35 miles a day to and from work, its a pretty uneventful travel. And yes the DOT does regulate all vehicles to operate at 87 octane, even the enzo does this, not optimal, but acceptable. If I plan on pounding on it, I'll run high octane, but for to and from work 87 should be fine, even if I get some crap gas the knock sensor will help me, and I've got a very keen ear to detonation if worse be. Good discussing, I appreciate the replies.
Old Feb 6, 2005 | 10:01 PM
brad66247's Avatar
brad66247
only 93
Old Feb 6, 2005 | 11:48 PM
slicksilver11's Avatar
slicksilver11
Only use premium - That is what is recommended and it only cost a little extra.
