The 34/78. Higher capacity than the 75/25. It should come with a new hold down block for GM, Chryslet, or Ford cars. Most use the stock block with no problem.
I have a 34/78 also & like ptdummer said, fit's like a glove and both of the cables reach the new posts, be sure you get the correct hold down for the Optima, it's the one that fits between the cylinders
I'm replacing my positive battery terminal.
I had to cut off about 1/2 inch of wire.
Which one (75/35 or 38/74) is the shortest (requires the least battery lead wire)?
