Clutch install... how hard?
The search works again!!!!
http://forums.corvetteforum.com/show...lutch+tutorial
Will this tranny jack work if doing it on jackstands?
http://www.harborfreight.com/cpi/cta...emnumber=39178
FWIW I would imagine a tranny jack would make this job a lot easier!
Robert / Gen 3 Motorsports
Please don't laugh, I know it's a long time, but I think I could do it in half the time next time around (God forbid).If you are mechanically inclined and have lots of tools, ratchet extensions, and a couple big-daddy jacks, then I say go for it.
The only change I would make to Dope's install guide is the following.
There is one part at the beginning when he talks about getting the e-brake clip out of the retaining bracket, and he mentions that it is a real pain. He talks about using vice grips and lots of little screw drivers to push in all the prongs so it can slip out of the bracket. I screwed around with this for 30 min before giving up and going a different route that I would recommend to anyone.
Just unbolt the mounting bracket!! It is secured by 2 bolts and comes off easy. Once the bracket is off the wheel hub, it's super easy to get access to get that e-brake line out of the bracket.
There are two drawbacks to this:
1. You must pop off your rotor to screw the mounting bracket back in, because these screws secure into the e-brake adjuster assembly, and once you take the bolts out, the assembly will get out of alignment and your bolt holes won't line up anymore. Kind of hard to explain, but it only takes 5 min to pop off the brake-pad retaining bracket and slide off the rotor. In my opinion, much faster than messing around with that darn 1-way locking tab stuff on the e-brake line in a confined area.
2. You must remember to bolt that bracket back on before reattaching the lower shock mount bolts when you're finishing things back up. Otherwise, the shock gets in the way and you'll curse yourself for having to take anything back apart at that point because you are so incredibly sick of having the car apart. Only took me 5 min, but still... Just bolt it back up right after you take it off, after removing the e-brake cable.
Good luck, I say go for it!
[end of quote]
I concur with removing the bracket, it is a much easier way. On the re-install, I did not have to remove the rotor at all.
And, to answer the question of the thread, that being how hard to install, I would say for the first timer it is a biyatch and somwhat intimidating, especially wiggling around on a garage floor. It can be also a tad bit disheartening to see (and your neighbors) your entire undercarriage of your pride and joy strewn across the garage floor. The advice of not setting deadlines is golden as for dmn sure you don't want to make a mistake and have to do it over again.
Once you have been through it and everything is working well, you will have the sense of accomplishment of doing the job yourself and also knowing more about the C5 than 90% of other owners.
Other advice I may mention is to consider now for any improvements to the driveline, exhaust, tranny braces, tunnel brace etc as you will be definately "in there" .
Good luck.
If you can't find it, e-mail me and I'll send it to you.
