need help!! how do you stop wind noise?
Old Feb 6, 2005 | 10:41 PM
BAD Z06's Avatar
BAD Z06
Default need help!! how do you stop wind noise?
when i drive fast (every day) air comes from the top of the window..does anyone know how to fix that?
Old Feb 6, 2005 | 10:44 PM
GEAUX's Avatar
GEAUX
Loud Radio?
j/k
Check the window alignment. Sometimes it can be a bit off and tilted out of alignment allowing wind noise.
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
I have never done the adjustment before. There are a couple of different adjustments available.
http://www.***-internet.com/johnden...dow_tip_in.html
http://www.***-internet.com/johnden...owout_clip.html
Hope this helps.
Old Feb 6, 2005 | 10:58 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Hope this helps.
Dead links.
Old Feb 6, 2005 | 10:59 PM
2K Vette's Avatar
2K Vette
Stickman81,
Those websites didn't work for me.
Old Feb 6, 2005 | 11:30 PM
MOP450's Avatar
MOP450
Try this,
http://forums.corvetteforum.com/showthread.php?t=941183
Old Feb 7, 2005 | 11:05 AM
UTHockey17's Avatar
UTHockey17
I had the same problem, took it to the dealership and they told me it was regular road noise and they could do nothing about it. #1 make sure that your top is seated correctly(all weather striping is laying correctly). #2 if the top is on right then try tipping in your windows, try this link http://www.johndennington.com/
To need help!! how do you stop wind noise?
