Hood latch
Old Feb 7, 2005 | 06:44 AM
skyman51's Avatar
skyman51
Default Hood latch
More often then not when closing my hood, the left side does not latch. Everything appears to be working normally. What adjustments if any are there to check, or what is the fix for this? Thanks.
Old Feb 7, 2005 | 08:15 AM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
The latch is adjustable. Loosen and raise it up just little to see if it will catch the striker. It will probably take a couple of adjustment to get it perfect
dlj
Old Feb 7, 2005 | 12:45 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Try pushing from the center of the hood near the windshield as you close it and it usually catches both latches.
Old Feb 7, 2005 | 12:49 PM
fast2000vette's Avatar
fast2000vette
Mine will do that unless I drop it from about 2 feet up. I think this is pretty normal. Good Luck.
Old Feb 7, 2005 | 01:50 PM
Army Vette's Avatar
Army Vette
I have the same problem with my hood. I will work on the adjustment this week - is it pretty straight forward?
Old Feb 7, 2005 | 04:06 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Well I do the drop from 12" or so. I have seen many Vette owners at shows gently set hood down on latches and then push strait down with a towel in hand to seat each latch. Most do right side 1st then left. I only push by hand if they fail to latch at 1st drop.
Old Feb 7, 2005 | 04:50 PM
FallenWhun's Avatar
FallenWhun
I have this problem too on the passengers side. I have to push down on the darn thing to latch...like im doing cpr on the darn thing.
To Hood latch
