GM / Dealer Labor Operation Codes??
Old Feb 7, 2005 | 05:50 PM
carbdude's Avatar
carbdude
Default GM / Dealer Labor Operation Codes??
HELP...
I've gotten the Vehicle Inquiry System (VIS) history report sheets on a car that I'm looking at, and the 'Claim History' shows the following;
V0743 - ECI Relay Harness Replaced @ 7500 miles
( what does this HARNESS control or go to ?? ) and
N4800 - Module, Computer ( Control ) Body - Replace @ 8200 miles
and again @ 10,500 miles
( what does this Module control?? and why would it need to be replaced twice in less than 2 years ?? )
Thank you ALL!! Larry
Old Feb 7, 2005 | 07:18 PM
gtzy's Avatar
gtzy
probably steering column lock related
Old Feb 7, 2005 | 07:45 PM
JackTsDBG's Avatar
JackTsDBG
Originally Posted by carbdude
HELP...
The BCM monitors/controls everything from headlights, fog lights, DRLs, console lamps, defogger, horn, column lock, hatch release, top release, well you get the picture. The BCM is located in the passenger footwell. Replacement could be related to column lock, but could also be related to the leaking battery side terminals that are supposed to be common in earlier cars. The lead/acid battery, not the AGM batteries used in later cars.
Old Feb 7, 2005 | 08:46 PM
NoNeck's Avatar
NoNeck
How can I get a VIS for my car? I bought it used and would love to know the history, especially because it's an '01 Z06.
Old Feb 7, 2005 | 08:51 PM
ragtopws6's Avatar
ragtopws6
Take it to any GM dealer and ask to VISS your vehicle for any open recalls/campaigns...........It's free and if you ask politely enough you can get a copy.
Old Feb 7, 2005 | 09:23 PM
JackTsDBG's Avatar
JackTsDBG
There was a car salesman, karguy6 I think, who was offering these to forum members several months ago. Worth a search for the llink.
Old Feb 7, 2005 | 10:00 PM
Shall's Avatar
Shall
St. Jude Donor '05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-‘16-‘17
HELP...
Steering lock campaign according to my receipts. Did they put a 88952427 harness K on it?
No idea on the other...you can always stop by a GM dealer..they should be able to tell you.
To GM / Dealer Labor Operation Codes??
