I have EradiSpeed +1 rotors on the rear of my Z06. The Zinc plating wears off the surface of the rotors where the pads rub. This surface with rust if exposed to moisture. The rest of the rotor stays without rust, but the pads quickly remove the rust once you start driving.
I am satisfied my mine. Good luck with your decision.
