Sway bar link Q's
Old Feb 8, 2005 | 10:13 PM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Default Sway bar link Q's
I have heard that using the Hotchkis end links on the T1 bars is a good fix for the noise and other issues.
Anyone have any insight into this?
Thanks,
Jeremy
Old Feb 9, 2005 | 12:37 AM
DirtyRed's Avatar
DirtyRed
Not so. The Hotckiss endlinks are similar in design to the T1's. Do you plan on doing any track time or will it be a daily driver? If you're going to the track ypu may want to contact Guldstrand for info. If you're looking for street performance the standard OEM aluminum links will work fine. I have T1's on my 01 F45 and am running aluminum links with no noise or breakage problems.
