Help with door switch LED install
Old Feb 9, 2005 | 01:06 AM
CUlookin's Avatar
CUlookin
Default Help with door switch LED install
Hey guys, I am installing some Blue LED's in my door switches according to Spdkilz's instructions (Spdkilz.com). I've finished my passenger door side and I noticed that the lower area (under door luck/unlock) is not as bright... anyone else with this, or is it just me? Thanks!
Old Feb 9, 2005 | 01:10 AM
kingrobby25's Avatar
kingrobby25
I did mine a few weeks ago and all of mine were very dim. i checked and they were turned on just very dim. i couldn't figure it out as i purchased the correct supplies and followed the directions to a T. i just went back to stock as it turned into a pita.
Old Feb 9, 2005 | 01:11 AM
CUlookin's Avatar
CUlookin
yeah, the upper one looks great, the lower is dim... I wonder if it's how I cut down the LED's...
Old Feb 9, 2005 | 01:14 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Hey Rob-
What resistor are you using? 470 ohm with 5mm LED?
If you have access to 3mm LED, try that. Just don't push the bulb all the way down in the holder.
Dave
Old Feb 9, 2005 | 02:05 AM
kingrobby25
Thanks for the advice but I dont have the stuff anymore. I'll just leave it stock for now and concentrate on making some power. Thanks though.
Old Feb 9, 2005 | 02:08 AM
CUlookin's Avatar
CUlookin
I recut the passenger side one and it looks great! I got the driver side done and it looks even better! Can you do the Center Console A/H - Selective Ride controller? I don't see why not...
CUlookin's Avatar
CUlookin
oh yeah, I'm using 5 mm LED's with 470 ohm resistors...
Old Feb 9, 2005 | 02:49 AM
Cscokd's Avatar
Cscokd
YES...very easy to do
John
Old Feb 9, 2005 | 09:08 AM
CUlookin's Avatar
CUlookin
thanks guys for all your help
To Help with door switch LED install
