Noise When I Go Over A Bump
Old Feb 9, 2005 | 01:10 AM
mdbennes's Avatar
mdbennes
Default Noise When I Go Over A Bump
I hear a squeek in the front when I drive over a bump...is this something that can be fixed? I heard other people have the same thing, plus I noticed it more since its cold here in UTAH....any help would be great...
Old Feb 9, 2005 | 03:48 AM
H8TOW8's Avatar
H8TOW8
Check this out.... To Reduced squeaks, creaks and noises while driving.
The redesigned Tunnel Reinforcement Plate
http://www.eliteengineeringusa.com/C5Products.html
Old Feb 9, 2005 | 04:20 AM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
I suggest that you cease going over bumps,
Okay I'm sorry...it's late and I just couldn't resist!
I will feel guilty if I don't offer at least one plausible suggestion. I don't know how old your car is, but I have heard it suggested by numerous car guys to go through and tighten nuts, screws, etc once a year or so just to make sure that things stay buttoned up. Otherwise, some kind of chassis stiffening may help, then again, depending on the source of the problem, it may exascerbate the issue.
Old Feb 9, 2005 | 06:21 AM
mdbennes's Avatar
mdbennes
I have a 2000 coupe, someone I believe said that it could be the bushings being cold and stiff during the winter...its mainly over speed bumps etc....
Old Feb 9, 2005 | 08:25 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Your sway bar bushing have worn the paint off the sway bars.. rust has formed on the sway bars and the squeak is coming from the rust rubbing on the dry bushings... the fix is to remove the two front bushings and the two rear bushings.. clean the rust off the bushings and clean the sway bars.. repaint the sway bars, apply silicone grease to the bushings and reinstall. Torque to the proper specs...
front bushing torque 58 N-m 43 ft lbs
rear bushing upper torque 65 N-m 49 ft lbs
rear bushing lower torque 95 N-m 70 ft lbs
Old Feb 9, 2005 | 01:24 PM
mdbennes's Avatar
mdbennes
Great...thanks for the info EVIL...I was hoping it was something pretty simple, so to speak..
Old Feb 9, 2005 | 03:17 PM
C5 Curmudgeon's Avatar
C5 Curmudgeon
I had the same "problem". My dealer lubed the sway bar bushings and everything quieted down.
Evil-Twin's method may be more comprehensive, but what was done to my car did the trick.
Old Feb 9, 2005 | 04:25 PM
mdbennes's Avatar
mdbennes
Do you know what kind of lube they used?
Old Feb 9, 2005 | 06:48 PM
Evil-Twin's Avatar
Evil-Twin
You want to use a silicone grease, GM sells it , or you can get it aty any auto store.. you do not want to use any petro grease..no WD 40... these will cause premature bushing deterioration..
Old Feb 9, 2005 | 07:22 PM
DADEO's Avatar
DADEO
Hey me too.
I would call it more of a SQUAK over a bump or sharp dip.
My vette is a 99, And I have just noticed it doing this since it's been cold and wet for a month now.
I don't drive it in wet weather but I'm sure humidity works on everything around this part of the world. ( Southeast Texas )
And no I didn't run over a chicken
I have some silcone spray, do you folks think that will do the trick on the sway bar bushing ?
Old Feb 9, 2005 | 07:24 PM
mdbennes's Avatar
mdbennes
Thanks EVIL TWIN....sounds like a project for me this weekend or next week....Is it easy to reach the bushings with the car on ramps? Or will it be better to have it on stands?
Old Feb 9, 2005 | 07:47 PM
Evil-Twin's Avatar
Evil-Twin
The job is an easy one.. less than an hour...use ramps for the front.. and do the fronts... then back the car up on the ramps for the rear.. just take note as to how the bushing fits in the bushing clamp pocket.
Old Feb 9, 2005 | 08:19 PM
jimcork1's Avatar
jimcork1
Default Squeek
I took mine in under warranty and the rubber pads on the front spring were bad. They were replaced under warranty and the front end squeek and stopped. I still have the rear end squeek, and drives me nuts. I can only hear it on slow speed over bumps. You can bounce the rear end and still hear it. I suspect bushings and the silicon spray I hope will help. The dealer pretty much gave up after the front spring pads and said bring it back some other time and we will find it.
I guess I will have to crawl under it as I have done for my 64,, 72, ,,, 87 and nnnnnnow the 99 C5.
Old Feb 9, 2005 | 08:27 PM
mdbennes's Avatar
mdbennes
Great...thanks. Sounds like a good job for my father and I to work on when he stays with us next week...
Old Feb 10, 2005 | 09:51 AM
ericdwong's Avatar
ericdwong
I heard another thing to use from a different make, that is water resistant and non-harmful to rubber is Cornhead Grease from John Deer. Fortunately I live in farm country there is a John Deer dealer 10 min away.
To Noise When I Go Over A Bump
