Have a question...
Any help would be greatly appreciated?
Also, I have been suffering from piston slap, especially when its cold (seems a little more pronounced now that I am back from the track), but now I seem to be hearing a faint, faint tapping even after the car is warm. It may have been there all along, but I am just listening alot closer to it now after having been to the track. Is that normal to (faintly) hear piston slap after the car is warmed up?
Thanks gang,
Jason
See what codes remain, pay particular attention to any codes that have an "HC" after them. You didn't mention any warnings from the Active Handling Traction control so, after making a note, go ahead and clear the codes and check them again after a few days driving. Post any codes that have a "HC" after them on this thread.
http://www.stengel.net/diccodes.htm
[40-BCM] B0502H - RH DRL RELAY CIRCUIT
[40-BCM] B0507H - LH DRL RELAY CIRCUIT
[40-BCM] B2482H - BACKUP LAMP RELAY CIRCUIT
[40-BCM] B2587H - COLUMN LOCK / UNLOCK DRIVE (A)
[60-IPC] U1160H - LOSS OF COMMUNICATION WITH BCM
[A0-LDCM] B2282H - BATTERY #1 FAULT
[A0-LDCM] B2284H - BATTERY #2 FAULT
[A0-LDCM] U1064H - LOSS OF COMMUNICATION WITH BCM
[A0-LDCM] U1016H - NO DESCRIPTION
[A1-RDCM] B2283H - BATTERY #1 FAULT
[A1-RDCM] B2285H - BATTERY #2 FAULT
[A1-RDCM] U1064H - LOSS OF COMMUNICATION WITH BCM
[A1-RDCM] U1016H - NO DESCRIPTION
[A6-SCM] B2860H - NO DESCRIPTION
[B0-RFA] U1096H - LOSS OF COMMUNICATION WITH IPC
[B0-RFA] U1064H - LOSS OF COMMUNICAITON WITH BCM
[B0-RFA] U1016H - LOSS OF COMMUNICATION WITH PCM
Jeez this seems like a lot of codes, but I haven't cleared any codes since the last time at the shop. Some of them I am sure come from when my battery died last month. The rest dont seem like they would be affiliated with tracking, but with my limited knowledge I wouldnt know anyway...
Any info on these would be appreciated...
Jason
Jason
