Service traction control message- with codes!!
Old Feb 14, 2005 | 12:13 PM
Crispyc21's Avatar
Crispyc21
Default Service traction control message- with codes!!
C1725 RR Shock Absorber Solenoid (Short to Voltage)
B0332 Outside Air Temp Sensor Short to GND
B0337 Inside Air Temp Sensor Short to GND
B0361 Left Actuator Feedback Short to GND
B0365 Right Actuator Feedback Short to GND
I received these codes on the way to work this morning along with a “service traction control” message on my DIC. I didn’t get any idiot lights on the dash. Does anyone know where the ground points are for the above codes? I have a printout of the 13 ground points for the C5 but some are hard to get to and I rather have my search pin pointed. I don’t know how old my battery is but it’s not the original, it looks quite new. Volts are almost always above 13.
If you don’t think it’s a ground issue let me know what you think it is and if there is any way to test the actual part.
Old Feb 15, 2005 | 09:46 AM
Crispyc21's Avatar
Crispyc21
Any body, any body, bueller...bueller...
I did notice today when I start my car the battery volts goes down to 10.8 but then shoot back up.
