key fob program
Old Feb 14, 2005 | 03:12 PM
tbird's Avatar
tbird
Default key fob program
can someone tell me how to program a 99 key fob
Tbird
"THANKS YA'ALL
TBIRD
Old Feb 14, 2005 | 03:55 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
I Have a y2k. When I changed batteries 2 weeks ago. I held the unlock and lock buttons down for about 10 seconds, the car horn sounded and I was done. I was sitting in the front seat when I did this. If it works for you great if it does not you lost 10 seconds. Good luck!
Old Feb 14, 2005 | 03:56 PM
ragtopws6's Avatar
ragtopws6
Turn the ignition to ON.
Turn the radio to OFF.
Press the RESET button in order to clear any IPC warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button until FOB TRAINING message is displayed.
Press the RESET button in order to begin the programming sequence.
The message HOLD LK + UNLK 1ST FOB will be displayed.
Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
Old Feb 14, 2005 | 04:14 PM
Sixants's Avatar
Sixants
Ragtops got the answer!
Old Feb 14, 2005 | 07:23 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Old Feb 14, 2005 | 08:16 PM
Mitch97C5's Avatar
Mitch97C5
I just followed ragtop's instructions(literally 10 minutes ago) and it worked perfectly. I bought my new FOB transmitter from GMPartsDirect.com for $84 including shipping (I kept getting outbid on Ebay).
Old Feb 25, 2005 | 09:11 PM
tonycorvettehd's Avatar
tonycorvettehd
Default transmitter training????????????
Originally Posted by Steve92LT1
i have tryed over and over folling your instructions,for some reason i never see transmitter training i get tire training,,and that it in that catagory//any ideas?????? tonycorvettehd@aol.com
Old Feb 25, 2005 | 11:15 PM
ragtopws6's Avatar
ragtopws6
Are you pressing OPTION button until TIRE TRAINING comes up?
Old Feb 25, 2005 | 11:33 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Is this for 99 only or will it work on all C5s?
thanks
Old Feb 26, 2005 | 12:30 PM
ragtopws6's Avatar
ragtopws6
This is for all years.
Old Feb 26, 2005 | 05:48 PM
tonycorvettehd
everytime i try it no matter what i do i never see transmitter training its like its not in the menu,,,i only see tire training,do yoy think this car doesn't have that option?
To key fob program
