c5 Oil pressure guage...
Old Feb 15, 2005 | 01:14 AM
Young Will's Avatar
Young Will
Cruising
Default c5 Oil pressure guage...
ive noticed my c5 has very high oil pressure & i would like any input on what the hell is going on.. ive drove it a few short trips, but i dont want to do motor damage.. my pressure reads 100+ & the guage is full over to the right...
any luck? i think this could have happened after drifted up a curb on the right side...
new sensor time? what damages could happen with still driving the car. pressure stays up cold or hot.
thanks again
Old Feb 15, 2005 | 01:23 AM
RandW's Avatar
RandW
Turn key to on without starting engine, if oil pressure gauge pegs than most likely a bad sensor. Common problem. When you replace it check electrical connector for oil or contaminants and clean with contact cleaner. If there's crud on the connector the new sensor may only last a short time. Here's a good tutorial on replacing http://forums.corvetteforum.com/showthread.php?t=958008
Old Feb 15, 2005 | 01:48 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Mine does the same thing.. it's the sensor.. need to replace it
Old Feb 15, 2005 | 03:54 AM
Perry Mason's Avatar
Perry Mason
Same thing happened to my brother's '97 recently. DIC reads 129 and gauge is pegged. Must be a frequent occurence.
To c5 Oil pressure guage...
