stock spark plugs
Old Feb 15, 2005 | 03:22 AM
kingrobby25's Avatar
kingrobby25
Default stock spark plugs
Hello everyone, I am doing some maintenance on my 99FRC,(royal purple tranny and diff fluid, new brake fluid, belts and plugs, etc) and today i changed the plugs. my car only has 48,000 miles on it and the plugs that I pulled out are NGK PTR5C-13's. Are these the stock plugs? I have looked and searched many times and I have heard about the platinum pucks wearing out, these plugs looked like they had the pucks at one time but now are gone. I replaced them with NGK TR55's gapped at .058inches as suggested. I think chevy needs to give out skin replacemant vouchers with the vettes so that I can get back all the skin that I left around plug #7.
Old Feb 15, 2005 | 06:38 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
The car came with AC Delco plugs from the factory. Yes - changing the plugs on a car with exhaust manifolds is not finger friendly. Get yourself a set of long tube headers - makes the plug change MUCH easier
Old Feb 15, 2005 | 09:09 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Next time use a small extension a knuckle a long extension and then the ratchet, takes 10 seconds and no skin removal.
Old Feb 15, 2005 | 09:45 AM
Richin Chicago's Avatar
Richin Chicago
Delco was on strike in 1999 so a lot of cars got the NGK or Denso plugs. As far as I know they did not have any problems.
Here is a picture of NGK and Delco.
To stock spark plugs
