U-Turn Noise
I've got my car up for sale, and a potential buyer came by last night and noticed the sound while making tight, slow, left- and right-hand U-turns in my cul-de-sac. Figures! It was a deal-breaker, as he feared it was something potentially expensive.
I recall having heard these small noises years ago when the car was new, and I even reported them to the dealer, who couldn't duplicate them. But in the years since, I'd completely forgotten about them. Guess I don't make many U-turns, and the car's performance has been otherwise flawless. I only have 14,000 miles on it.
There's no warranty left, so any repair would be totally out-of-pocket for me. I had a '94 Z28 that did this (only worse), and the dealer fixed it by putting an additive in the differential. Of course, the Vette has a more complicated rear transaxle.
So two questions: 1) What is it? And 2) should I bother fixing it, or let it be the next owner's problem--if it even is a problem?
[kg54trains]do the same. gm-1052358 is the part number for limited slip additive. That is a start, if this continues it may require additional work. The additive should work based on the milage
________________________________________ ____________________
If you don't want to attempt doing it yourself, buy the additive and take the car to your local repair shop. There is a plug at back of the differential. Add about 4-6 ounches. This should take care of your problem.
If I can get at this thing and put in a few ounces of limited slip additive, I'd try it.
You might be able to do this yourself, it depends on how skinny you are!
[FASST LN]There is a fill hole and a drain hole. The fill hole is on top and would be obvious that by opening it, that it won't leak oil everywhere. The bottle is only 6 ounces or so, you would probably need to add only a couple of ounces.
When You're Right........You're Right
The bottle only holds 4 ounces, so half a bottle should be plenty.
The filler hole is a 10mm allen, you can see it underneath the car on the rear. You'll probably need an extension and a rachet, or breaker bar to get it loose. The bottle already has a cap designed to let you squeeze out the fluid. Then find yourself an open area and do about a half dozen tight figure eights to work the fluid into the clutches.
Things
Things like this are hard to find since you can't have it up on a lift and do a u-turn...
The filler hole is a 10mm allen, you can see it underneath the car on the rear. You'll probably need an extension and a rachet, or breaker bar to get it loose. The bottle already has a cap designed to let you squeeze out the fluid. Then find yourself an open area and do about a half dozen tight figure eights to work the fluid into the clutches.[/QUOTE]
Hey, this worked! I got the little bottle of fluid, and this past weekend I squirted it into the filler hole. I then went to a large parking lot and did several tight right- and left-hand circles, went for a drive, and then returned to the parking lot and did some more circles. The chatter is gone.
I think I'll contact that guy who wouldn't buy my car and let him know.
