Which thermostat???
Can you be more specific....harmful in what way? Poor emissions, not cleaning the oil.....what??
ECS reprogrammed my fans with LS1 edit.
Best that I can recall his point was that modern engines are programed to operate most efficiently at , I thinK he said, about 190 and so if you use a 160 you can not only decrease efficency but also build up deposits.
I think all this stuff about thermostats is BS - as far as I know the temp of a stat determines at what point coolant is allowed to enter the block from the radiator - the stat operates like a temperature sensative switch. THAT"S IT!
Once that thermostat opens IT"S OUT OF THE LOOP. It dosen't turn on and off or close down partially to control the temp of the coolant. If it's a properly operating stat once it reaches its' operatinng temp it fully opens and does nothing more untill you shut the car off.
It DOES NOT mean that if you have a 160 stat your car will run at 160 - I mean, follow that thinking to it's logical conclusion - if you use a 0 thermostat (NONE AT ALL) then your car should ( if the thermostat controls operating temp) not heat up at all. In fact in Ohio you could then run your car and use it to make ice cubes.
As ET said the temp your fans are set to come on , the speed your traveling, the amount of air passing over the radiator, the gear your running in ,your rear end ratio, the type of coolant in the car and the "openess" of the coolant path through the engine are some of the "really" important factors.
Don't believe it ? Next time you flush your coolant fill your car with plain pure water and go for a ride - note your running temp. Now drain the water and put you 50/ 50 coolant mix in and all the other protective additives you like to use and take a ride. What's going to happen ?? Operating temp will go UP - with the very same thermostate. Why ?
Sorry, that's not what you asked and I got off on a rant. I'm sure one of the members will chime in with some quotes from the article - I'm really suprised I'm the first to mention it - when I read it I was sure it would cause a stir.
Bob
the difference in trying to keep a C5 cool between 160 F and 210 F is a lot easier to maintain, then it is to keep a C5 cool between 190 and 230, with the ambient temperature at say 90F... the sweet spot on a C5 is 190/200 coolant and 200/210 oil temp.. keeping it close to the sweet spot is the job of the radiator, in combination with the fans.. having the fans come on earlier can only be done if the coolant is circulating sooner. The only down side to a 160 stat is running a tight clearanced, synthetically lubed C5 at 160 for long periods of time. If it is cool out side ( 50 F ) and your doing 80 on the interstate at night with no ground heat, Your coolant and oil temps at ( 160 F ) can cause carbon build up, increased combustion ratio, the need to do the famous GM de-carbonization process, engagement of knock retard and loss of performance.That's why I run two stats in my car here in the North east. 160 in the spring and summer,with fans adjusted and stock stat in the fall through early spring, with stock fan settings.
The screw is a M4.
I just add or remove the shims (tiny gaskets) to set the temperature I want. It needs gaskets to avoid leaks through the thread.
I first installed a 180F Hyper**** that did open later than my stock thermo (WTF!).
So I reinstalled the stock piece with the screw.
It goes from full open to 200F
