I had DTE for dinner!
Old Feb 16, 2005 | 11:13 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default I had DTE for dinner!
Yum, yum, yum.
Old Feb 16, 2005 | 11:17 PM
ICULUKN-C5's Avatar
ICULUKN-C5
sweet... you should take pics of your install.
Old Feb 16, 2005 | 11:20 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Congrats! I just got mine installed yesterday!
Old Feb 16, 2005 | 11:21 PM
Cajundude's Avatar
Cajundude
I did. I'm going to do another "how to" on the differential. I'll add the brace in there but it will be a little different since I already had my cradle and diff out.
Old Feb 16, 2005 | 11:22 PM
Cajundude's Avatar
Cajundude
Mine is in as of an hour ago.
Old Feb 16, 2005 | 11:56 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
WOW! That's the nicest workbench I've EVER seen!!
Best Regards,
Phil- DTE
Old Feb 17, 2005 | 07:37 AM
SS930's Avatar
SS930
Phil,
Any thoughts on you guys making your brace out of aluminum to shed some weight? I would think that would make the 'other' brace far less attractive.
Old Feb 17, 2005 | 09:39 AM
DTE Powertrain
Collections Hold
We already tested that well over a year ago with unfavorable results... The aluminum brackets fatique too soon, bow and often crack very early in the struts kit's life, not to mention the cost is much higher to manufacture.
Another thing....
We can't figure out why everyone is so "weight concious" about a~ let's face it...street car that is fully equipped with the bells & whistles the C5 Corvette does, other than it being "cool" for folks to discuss the topic as hardcore racers with *real* lightweight race cars do... Most folks we've seen at any track, anywhere, at any given time, have a street car-type Corvette that usually has heavy stereo equipment installed, bling parts installed all over the place and big heavy wheel/tire combo's with poor tires that are VERY heavy to begin with.
Why then doesn't everyone start asking themselves, "does the weight of these extra bling components affect my E.T.?" No...they just customize and install what they like for their car and take what the car will give them at the track. If folks want a lower E.T. further, they often add more power to cover it. Not to mention that everyone racing we've noticed usually has no real clue on how much fuel they had in their tank on a given run (or from run-to-run for that matter) which plays an important role in overall GVW of the car, weight transfer, etc.....
With that said, our product *only* weighs about the same as 3.5 gallons of gas which is NOTHING in the overall big picture of gross vehicle weight, especially compared to how folks commonly add weight to their car without a care because it "looks good" and until we see someone come to us with a gutted C5 Corvette that has no radio, CD, stereo equipment, no A/C, no interior, lightweight chassis, etc, etc, etc, (such as a full-tilt race-car like LGM's or something) we're not concerned about this issue. Afterall, the A4 kit *only* weighs 19 lbs. and the M6/M12 kit *only* weighs 21 lbs., so the benefits one receives with increased driveline durability using our product completely overshadows the argument of weight vs. strength by a longshot.....
I'm sure some folks will want to argue into infinity about this and theoryorize it to death, which is fine, but the reality of the issue still remains no matter how much someone accepts or denies it.
FWIW..
Best Regards,
DTE
Old Feb 17, 2005 | 10:19 AM
jrose7004's Avatar
jrose7004
Congrats on your mod!
Old Feb 17, 2005 | 10:32 AM
Cajundude's Avatar
Cajundude
DTE, you're absolutely right! I agree with you fully on that weight issue. It doesn't matter if there is 50 lbs. of chrome under the hood but you're product NEEDS to weight 12 lbs. less. Whatever. All I know is I got one and now I'm much better off when it comes to the driveline. Sometimes people just unfortunately need to learn the hard way and that sucks because it will shy people off from racing because of it. Well, on the other hand, sounds good to me. Less people in line at the track!
ICULUKN-C5, thanks! I'm putting the cradle back in right now. Had to take a break because that beotch is a heavy mo fo by yourself.
Old Feb 17, 2005 | 10:50 AM
SS930's Avatar
SS930
DTE,
Thanks for responding to my question. BTW, no bling here... nothing gets added to my car unless it makes the car faster and or more reliable.
The reason I asked the question was only partly because of weight concern. I have added many steel aftermarket parts over the years to a variety of vehicles and always end up with the same problem... chipping and rusting parts. The manufactures say how well their parts are primed, painted, or treated, but after a few years they all start rusting. I've learned if given the choice of aluminum or steel, I'll take the one that doesn't rust and weighs less.
I like the design of your product, I had just wondered if you had any intention on producing an aluminum version. Sorry I brought up what appears to be a touchy subject.
Old Feb 17, 2005 | 11:15 AM
DTE Powertrain
Collections Hold
Thanks for the questions and it's not really a touchy subject, but rather an opportunity to present the obvious realities of the weight issue.
We are aware of your's (and some other's) concerns regarding product finishing with the HD paints we use, etc. As of 2-12-05, ALL of our differential strut models have been further improved for your benefit in that they now are powder-coated for increased finish durability and further strengthend by using tempered steel instead of cold-rolled steel~ all without adding to the overall weight of the product. Both designs are very strong and durable, but there is ALWAYS room for further product refinement as time wears on and we are dedicated to that pursuit with our driveline products, differentials and services.
Best Regards,
DTE
Old Feb 17, 2005 | 12:07 PM
BLU-BY-U's Avatar
BLU-BY-U
Originally Posted by SS930
DTE,
bottom line is, guys installing "chrome under the hood" or "high powered amps and subwoofers" are not the target market for any of the available braces on the market. These are the typical type owners that enjoy cruising the car and making an occasional blast down a 1/4 mile on street tires, most likely launching off idle.
IMO, the target market for these braces are the "hardcore" drag racers that intend on HIGH rpm launches on sticky tires. This type launch are the scenarios where breakage will most likely occur. These are also the type owners that do indeed want to watch the weight on the car. I certainly try and show up at the drag strip with 1/8 tank or less, preferably tripping the reserve light as I enter the facility.
Now I will add the fact that the additional weight is towards the back of the car, which is definitely a favorable place to add weight if one has to. But that still doesn't mean that core market drag racers aren't looking for the lightest components available that get the job done....because they most certainly are.
Old Feb 18, 2005 | 05:09 PM
jnsfeeney's Avatar
jnsfeeney
Another thing....
We can't figure out why everyone is so "weight concious" about a~ let's face it...street <A TITLE="Click for more information about car" STYLE="text-decoration: none; border-bottom: medium solid green;" HREF="http://search.targetwords.com/u.search?x=5977|1||||cars|AA1VDw">car</A> that is fully equipped with the bells & whistles the C5 Corvette does, other than it being "cool" for folks to discuss the topic as hardcore racers with *real* lightweight race cars do... Most folks we've seen at any track, anywhere, at any given time, have a street car-type Corvette that usually has heavy stereo equipment installed, bling parts installed all over the place and big heavy wheel/tire combo's with poor tires that are VERY heavy to begin with.
FWIW..
Best Regards,
DTE
Well said on the weight issue. It's funny - you'd think some of us would be dieting like crazy, pulling carpets, passenger seats, etc. for weight savings with some of these comments. These are NICE sports cars - the total package
Old Feb 18, 2005 | 06:47 PM
99 The Hard Way's Avatar
99 The Hard Way
What's involved in the install? Can't wait to see pics. Does this cure wheel hop, or just lessen it? I know the main objective is added strength, but I need to cure my wheel hop issues!
SCOTT
Old Feb 19, 2005 | 02:46 PM
busavette's Avatar
busavette
Another thing....
FWIW..
Best Regards,
DTE
DTE,
I'll be calling this week. I'm in need of a 4.10 diff and the brace for my 01 m6 coupe. I'm not concerned about the weight of the brace, if I was I'd just lose a few pounds myself.
Old Feb 19, 2005 | 08:57 PM
2000silvervette's Avatar
2000silvervette
are these ever going to be on sale I need one bad in my 600rwhp c5 thanks
Old Feb 20, 2005 | 10:10 PM
Cajundude's Avatar
Cajundude
SCOTT
You have to completely remove the rear suspension to get the diff out. It's pretty easy, just time consuming. You can do a search and find instructions. I will also make my own how to within a week or so.
To I had DTE for dinner!
