Z51 lowering
Old Feb 17, 2005 | 06:38 PM
gamisou's Avatar
gamisou
Default Z51 lowering
Is there any concerns when lowering a coupe if it came with Z51 rpo. Is the procedure the same? Any comments on wether I should and how to do this is appreciated. Also how far off is the alignment when done, I don't want to max out of factory adjusters.
Thanks Steve
Old Feb 17, 2005 | 10:56 PM
corvette dave's Avatar
corvette dave
Steve,
No problem lowering a Z51 car.
You have to answer the question whether you should lower the car.
The obvious con is scraping the front spoiler.
No way to tell how far the car wil be out of alignment after lowering. It depends where the alignment was before the car was lowered.
Always have the alignment checked after lowering. It will change.
Try it. You can always raise it back up easily.
Someone will chime in with the link on how to lower the car done by Patches.
Dave
Old Feb 18, 2005 | 06:43 AM
VetteSiNz's Avatar
VetteSiNz
Here's a link on how to lower your car. http://www.c5forum.com/diy/lowering.php
Old Feb 18, 2005 | 06:47 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Thanks Steve
I lowered mine as far as it will go on stock bolts. It is still settling - make sure you allow for some driving time before you make any adjustments (a few hundred miles). My car does not pull left to right - and my measure of the alignment shows it is not too far oof - especially for running just to let the suspension settle - I am going to take it somewhere and get an alignment though - These tires are FAR too expensive to take the chance on the alignment being out enough to wear the inner part of the tires.
Old Feb 18, 2005 | 04:36 PM
gamisou's Avatar
gamisou
thanks for the info guys thanks steve
Old Feb 18, 2005 | 04:50 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Mine is a lowered Z51 and without any problems. I'd suggest that you let it settle for a week or so then get a 4-wheel alignment.
To Z51 lowering
