Left Break lights are out (short)
Old Feb 17, 2005 | 07:02 PM
juser250's Avatar
juser250
Default Left Break lights are out (short)
My left break lights are out. The bulbs seem to be fine, and the turn signal works as well. The rear lights also work when the lights are turned on. What is wrong, is it a short? How do i go about fixing this promlem?
Thank you for your reply.
Old Feb 17, 2005 | 11:14 PM
lloyd's Avatar
lloyd
test your system with the 4-ways on & see if the left brake lights flash - please let us know
Old Feb 18, 2005 | 01:31 AM
erikszr1's Avatar
erikszr1
brakes
Old Feb 18, 2005 | 01:10 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
The bulbs are dual filament so you need to be sure both are working. Beyond that you would need to jump into wiring diagrams to see how 12V gets to them for the brake light circuit, and trace it to see where it may be dropping.
Old Feb 18, 2005 | 06:50 PM
99 The Hard Way's Avatar
99 The Hard Way
That happened on my 99, and it was the turn signal switch. Just something to keep in mind, if the other checks fail. Scott
To Left Break lights are out (short)
