transgo-4L60E 98vette????'s
Old Feb 17, 2005 | 09:17 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default transgo-4L60E 98vette????'s
Doing my install and ready to move on,i think.My ?? is,the video differs from the written inst,i know it's an overview.Directions say to follow written inst. But,there is one plate on the side of valve body that has 3 screws holding it down. The video shows adding 2 springs to it(large white),My inst. show none of this,and i do not have those 2 white springs. I have 1 spring thingy for the screen in the separator plate. I have 1 large yellow spring for the 4th accumulator(still in bag)and 2 orifice plugs. I have not removed the separator plate yet or the check ball that goes w/ it.
The video says there ARE 6 check *****,I HAVE 7(INST SAY SO)
MY PAN HAS A LARGE DIP IN THE MIDDLE OF IT(NOT FLAT-16 PAN BOLTS).VIDEO DOES NOT SHOW THAT EITHER!
I have to do a few more things and then refill,drill plate,do 4th accumulator,gasket and then wrap it up.
I did search and read post's by JAWSKI AND VSTELLA,but pics did not come up. I need some clarification here for my sanity.
Thanks,Matt
Old Feb 17, 2005 | 09:48 PM
6spd89's Avatar
6spd89
Default ttt
ttt
Old Feb 18, 2005 | 05:18 AM
6spd89's Avatar
6spd89
Default ttt
ttt
Old Feb 18, 2005 | 08:04 AM
quimbo's Avatar
quimbo
Why dont you go to the transgo web sight get there phone# and give them a call http://www.transgoperformance.com/ better yet here it is hope this helps you out Bro!!!!!!!!!!!!!
TRANSGO PERFORMANCE
DEPT. W.S.
PHONE:
(626) 443-4953
FAX :
(626) 443-1079
MAIL:
2621 MERCED AVE.
EL MONTE,
CALIFORNIA 91733
QUIMBO SEEYAAAH
Old Feb 18, 2005 | 03:55 PM
KRK's Avatar
KRK
TransGo Tech support line 626 443 7493
I just finished my install last week and had/have many of the same questions as you. Also, jawski made reference in his thread that one of the valves was inserted backwards in the printed instructions, but he didn't elaborate and I went ahead and followed the instructions. I will get to see if the car is be able to move out of the garage this weekend.
If you want to review or compare installation procedures, let me know.
Kalin
Old Feb 18, 2005 | 05:08 PM
6spd89's Avatar
6spd89
Default ok
I called Transgo(thanks for the numbers!),and they said Follow the instr!!! That is a very generic overview and thw written word is the gospel!! I do not need those 2 white springs(didn't have them anyway).
I need to go get the right filter now for my tranny. The other one is missing an extension of the filter bottom that goes down to the lowest portion of the pan. I need to pull the separator plate next,hopefully tonight. Thanks KRK!!
Matt
To transgo-4L60E 98vette????'s
