off road x-pipe?
Old Feb 18, 2005 | 06:56 PM
not08crmanymore's Avatar
not08crmanymore
Default off road x-pipe?
so,what exactly does that mean?i can't use it on the street?any bigger gains from it?thanks.
Old Feb 18, 2005 | 07:44 PM
Face's Avatar
Face
Offroad X pipe means it eliminates the cats. Gains vary, depending on your mods.
Old Feb 18, 2005 | 07:50 PM
not08crmanymore
so,what happens when cats are elimated?codes?fail inspection?thanks.
Old Feb 19, 2005 | 08:37 AM
blktie8's Avatar
blktie8
You will need to get it in for tune to remove the codes .
The hi flow cats are the way to go
If you do remove the cats and run a off road x pipe you will need 02 sims
or an ls1 edit tune
the tune helps and is a must for max hp with headers and an off road pipe
Old Feb 19, 2005 | 08:44 AM
not08crmanymore
Default pipes
thanks for the info.lastly...is it worth the money?
Old Feb 19, 2005 | 10:13 AM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Do you mean just the x-pipe or a new long tube header system? I dont really see much of a point to buying just the x-pipe (maybe a few horsepower and it will mellow out your exhaust sound if you currently have an aftermarket catback exhaust) unless it is in combination with the long tube headers and a new catback exhaust. Spending over $2000 on a new exhaust systm is really up to you and if you really need more rwhp. You are probably looking at around a gain of 35rwhp with a new exhaust setup (LT headers and catback). good luck
Old Feb 19, 2005 | 12:49 PM
not08crmanymore
thanks.
To off road x-pipe?
