New Rotor Break In ?
Old Feb 20, 2005 | 09:47 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default New Rotor Break In ?
I put the VNM rotors on and I'm getting a pulse in the brake pedal. I didn't change the pads yet, since I wanted to wear off the Zinc coating before I put on new pads. I'm hoping that the pulse will go away as the coating disappears. I torqued the wheels to 100 ft. lbs. so I know I didn't warp them. Anyone else experiece this?
Old Feb 20, 2005 | 10:00 AM
Mighty-Mouse's Avatar
Mighty-Mouse
yes someone has experienced this:
http://forums.corvetteforum.com/show....php?t=1014553
The zinc coating will have an effect.
Drive the vehicle to a remote area and perform at least 30 brake applications of 3-second duration. Use light/medium deceleration with varying starting speeds. Leave at least 10 seconds between each brake application.
Old Feb 20, 2005 | 10:06 AM
Mark 84ltblu
Curise-In V Veteran
Thanks! i did a search but didn't find that thread.
Old Feb 20, 2005 | 10:23 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
be careful..brake fade
Old Feb 20, 2005 | 10:46 AM
supercoupe01's Avatar
supercoupe01
They are a little weird feeling at first but once you get the pads worn into the rotors and the coating gets worn off they should be fine.
Old Feb 20, 2005 | 11:07 AM
Mark 84ltblu
Curise-In V Veteran
I've been taking it real easy till I get them properly bedded.
Old Feb 20, 2005 | 04:25 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
They need to be cut!
To New Rotor Break In ?
