How To Remove Fuel Pump From Housing??
Old Feb 20, 2005 | 03:18 PM
babala65's Avatar
babala65
Default How To Remove Fuel Pump From Housing??
Replacing my intank fuel pump I need to know how to remove it from the big white plastic housing?
Old Feb 20, 2005 | 03:28 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
IIRC, you have to pry off one end of the housing. Lots of guys have done the Racetronix upgrade though, so maybe someone with a little more memory than I will respond...
Old Feb 20, 2005 | 03:58 PM
babala65's Avatar
babala65
Its looks to be 1 pc.?
Old Feb 20, 2005 | 04:28 PM
jers98vet's Avatar
jers98vet
A small flat screwdriver and plenty of patience will separate the two. When replacing the pump, make sure to replace the crimp clamp on the flex feed lineand make sure it's crimped well or it could come off the pump. Had this happen to me last week.
Old Feb 20, 2005 | 07:49 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
https://www.aandacorvette.com/racetronix_fuel_inst.asp
Make sure your tank is 100% clean and you replace the fuel filter.
Before running the new pump make sure you have 10 gallons of fuel poured back in the tank and let it sit for apx. 15 minutes before firing it up.
Old Feb 21, 2005 | 06:47 AM
babala65's Avatar
babala65
I got it! Thanks...
To How To Remove Fuel Pump From Housing??
